Question about Car Audio & Video
Eclipse DA7122 amp
When i first hooked it up it did light up with power all my cables and weirs are good cuz i hooked up my other amp to see and it worked fine but wean i huked my eclipse amp back up it light up for a min then went out and still no sound i pulled the back off and lookd for loss wiers and found nthn i thnk the bord in it went out is ther any way to get a new one.
  • sunny bird Apr 09, 2008
    think my bord burtout can i get a new one for it its a 2000 watt mono channel amp its a Da7122 ser
    its a eclipse DA7122 amp can i get a new bord for it think it went out .
  • 323 Answers
Did you hook up your other amp again to make sure nothing happened in your wiring? *curious*
Posted on Apr 11, 2008
My eclipse amp DA 7122 doesn't put out any power, no fuses are bad and led lights up. I must have a short some where?...any suggestions
check your rca cables and remote wire or wires and also check the wires to the speaker and in the box and if you have a friend that has a set up in there car swap amps to see if it works any different if it dont you may be able to get it fix at a car audio shop.
Dec 28, 2010 | Eclipse DA7122 Car Audio Amplifier
Sony radio sub outputs don't work at all
you may need a new head unit. it sound like you have lost the fron rca hook ups on your unit. common prob. usually cause by a surge traveling then the rca cables. i myself have had this happen and there is nothing you can do to the unit to fix it.
Sep 26, 2009 | Sony XS-V1330 Coaxial Car Speaker
Rmp stops, lights dim, radio turns off, losing power in engine
Check belt(s), alternator charging, battery & all connections are clean in good shape & tight, especially ground cables or straps.
Jul 08, 2009 | 1999 Mitsubishi Eclipse
Power problems with eclipse avn 5500 to amp
the avn 500 does not have a sub output. they have to create one at the shop-
Mar 24, 2009 | Eclipse AVN5500 Car DVD Player
Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
Nov 16, 2008 | Eclipse CD2000 CD Player
DA 7122
I have yes, but you have to turn the gain down on the amp below what you normally would
May 28, 2008 | Eclipse DA7122 Car Audio Amplifier
Audiobahn A2502DP amp is alive but wont talk to me
Your "bumpin" may have killed the amps "bumpin" Was the amp secure when you were sliding? So wires are ok, and lights and finas running. You have power but no output..Check the settings on the amp, also the fuse. Something might be earthing itself to the amp as well.
Feb 14, 2008 | AudioBahn A2502DP Car Audio Amplifier
No output when I play a CD
what kind of vehicle do you have? i am going to guess your vehicle has a stock amp that it uses to power your speakers? you will have to hook up the remote wire for the amp to the wire that powers the amp in your vehicle (the stock amp) right now it seems like you have the "power antenna" wire hooked up to the stock amp in your vehicle.
Aug 24, 2007 | Eclipse CD7000 CD Player
Eclipse CD8445
make sure that the additional box is hooked up to the cable, or else the display will not function
Oct 16, 2006 | Eclipse CD8445 CD/MP3/WMA Receiver
Car Audio & Video Logo
137 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
