Need the specs for HP DV7 Laptop motherboard #486542-001. Most interested in what AMD Turion X2 cpu's this motherboard supports
    President:
  • 1,561 Answers
Microprocessor 2.26 GHz Intel Core 2 Duo Processor P8400
Microprocessor Cache3 MB L2 Cache
Memory 4096 MB
Memory Max8192MB
Hard Drive 320 GB (5400 rpm)
Take care.
Posted on Jun 01, 2010
HP/Compaq 488194-001 6535B 6735B diagram
When one asks for a diagram of a motherboard, one is asking;
1) What type of Ram Memory slots, and how many,
2) What the internal connectors on the motherboard are,
3) What the motherboard chipset is,
4) What Processor (CPU) socket is used,
5) Plus a host of other questions.
6) What time will Mom have supper ready?
NO,.........not that last one. Just wanted to see if you were following along.........
K.
Let's do it this way. How about the Service Manual?
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c02030223/c02030223.pdf
Plus view images of the motherboard,
http://www.ebay.com/itm/HP-6735b-Main-pcb-no-post-488194-001-with-prosessor-ZM-80-AMD-Turion-X2-/170999202777?pt=LH_DefaultDomain_2&hash=item27d058c3d9
The main view shown, automatically opens to a Bottom view of the motherboard.
Put your mouse cursor in the middle of the photo, and use the Zoom In feature.
See the white Processor socket? Rectangle shape with 2 corners cut off, and a flat tip screw in it. Has an AMD Turion X2 Ultra processor sitting in it.
That is a Socket S1 processor socket,
http://en.wikipedia.org/wiki/Socket_S1
The graphics chipset is to the Left. Mounted to the motherboard with a BGA surface mount. Ball Grid Array,
http://en.wikipedia.org/wiki/Ball_grid_array
In the next link scroll down a little, click on the Red ->
Take a few minutes to view the IR 650 demo video;
to see an SMT/BGA Rework Station at work, and learn more about the BGA surface mount,
http://ersa.com/art-ir-pl-650-346-1472.html
The motherboard chipset is an AMD 780G that is for a laptop.
-> Mobile.
So it is an AMD M780G,
http://en.wikipedia.org/wiki/Comparison_of_AMD_Chipsets#A-Link_Express_II
Scroll down to AMD 780G chipset.
http://h10010.www1.hp.com/wwpc/us/en/en/WF06a/321957-321957-64295-321838-3955547-3687645.html?dnr=1
Northbridge chip, of the motherboard chipset; is the AMD M780G.
The Southbridge chip is an AMD SB700, or SB710, or SB750,
This motherboard diagram, works for the HP 488194-001 motherboard,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The HP Support link above states what;
A) Processors are supported
B) Ram Memory that is supported. What the TOTAL maximum amount for the motherboard is, and what the Maximum Amount is for Each ram memory slot.
C) No. It does not use a graphics card. The graphics are Integrated Graphics.
In conclusion; What are the specific question/s you have?
Post back in a Comment.
Regards,
joecoolvette
Mar 02, 2013 | Computers & Internet
I have a HP Pavillion dv7 with a AMD Turion X2 64 processor. The system hangs sometimes before Windows OS has a chance to boot\initialize and sometimes right after POST. Ran memory checks and hard disk...
Hi david simms,
What you're thinking about the problem with the CPU is correct. Though you need to consider if it is overheating. Here's a simple step to further determine it.
Just access the BIOS setup by pressing F2 (or whatever is key is designed for the unit). Let it sit there and observe if it will freeze up, if yes, surely your guess is right.
Hope this helps.
Jun 02, 2011 | HP Pavilion dv6000z Notebook
Tengo una laptop hp dv7-1245dx, al encenderla un dia me presento esta falla, se escucha que arranca pero la pantalla no enciende y los led de caps lock y num lock parpadean 1 vez cada 2 segundos, segun la...
Dv7-1245 todav?a es un port?til muy agradable.
El procesador se encuentra en su dv7-1245 es el
AMD Turion X2 con tecnolog?a m?vil RM-72 / 2.1 GHz
un reemplazo para ese procesador corre alrededor de $ 190 aqu?
http://www.pcrush.com/product/AMD-Processors/236482/AMD-Turion-X2-RM-72-Dual-core-2.1GHz-Mobile-Processor#product-reviews
o se puede disparar para una actualizaci?n de un 2.4ghz 250 aqu?
http://www.google.com/products/catalog?q=socket+s1+processor&um=1&ie=UTF-8&cid=14671136682080307777&sa=X&ei=vTNvTdOYHoHAtgfl7Jz2Dg&ved=0CCEQ8wIwAg#
Cualquier procesador Socket S1 trabajo en el dv7
Si esto le ayuda a asegurarse de que lo diga:)
Mar 03, 2011 | HP Pavilion dv7-1245dx Notebook
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
I have a HP Pavilion DV9418 17" laptop with AMD Turion 64 X2 Dual-Core TL-58 1.9GHz I am told by Staples it has a short in the motherboard where would I buy a new motherboard, hirst9@sympatico.ca
the best place to buy any laptop motherboard is Ebay. Most computer stores or repair shops they don't carry motherboards due to the vast option of brands/models and remember each laptop has an especific size, number of ports, etc.
Just keep in mind when looking for your motherboard make sure is for the CPU you have.
If you search DV9418 on Ebay you might get one for Intel CPUs and others for AMDs. If you have the motherboard's part number would be the best.
I hope this helps.
May 06, 2010 | HP (D7580-60003) Motherboard
Amd turion serial ata drivers
Go here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-41728-1&lc=en&dlc=en&cc=us&product=3263216&os=228&lang=en
Download and run the file and it will extract the contents into C:\swsetup\SP33031. Inside there will be an IDE\WinXP folder. Those would be the drivers you'd want to slip into your new disk.
Jul 02, 2009 | AMD Turion 64 X2 TL-56 CPU
I don't have a problem. I just need to know what kind of motherboard my PC has. its a HP Pavilion dv7.1135nr . thank you
I am guessing you are asking because you want to upgrade it?
If not, download this free program, and it will tell you all the info you want to know about your computer: CPU-Z here: http://www.cpuid.com/cpuz.php
Okay, well you have an AMD based DV7,
The 780G chipset is among the latest from AMD. That chipset supports the Turion ultra processors.
Your system may be running slow because your cpu is running at 500MHz instead of 2Ghz.
You can upgrade your processor to any RM/ZM/QL turion processor.
The processor in your system is socket S1
Your current cpu is a RM-70, 2.0Ghz dual core, 1mb L2, and 31 watt TDP
The RM-74 would be an upgrade to 2.2Ghz dual core, 1mb L2, and 35 watt TDP
However your best upgrade at the moment is the ZM-86,
The ZM-86 is 2.4Ghz Dual core, 2mb L2, and 35 watt TDP
The ZM processors are going for around $200 on ebay
I do not think the 400MHz upgrade is going to be worth $200.
Jun 25, 2009 | Computers & Internet
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
