Kenmore Model 22722 will not drain
Kenmore 70 series Model 22722 completely shuts down following agitation cycle and prior to rinse cycle. Washer will agitate properly, but just completely shuts down at drain portion. Help?
  • Washing Mach... Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineKenmore Model 22722 will not drain - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load WaKenmore Model 22722 will not drain - 2_bing.gifine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 01, 2010
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore 70 series washer model 22722 will not spin or agitate
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 14, 2011 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
I have a kenmore heavy duty, series 70,# 82872120.. It makes a humming noise and will not complete the rinse cycle or the spin cycle.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82872120
If it goes through the agitate cycle, the motor and transmission are probably OK.
If it goes through the initial drain / spin cycles after the first agitate cycle, the Lid Switch is also OK.
The humming could likely be the timer motor. Try to manually move the timer to the rinse cycle. If the washer responds, the problem points to the timer itself.
See the sub component section on the Sears site for the Console.
The "Alt" part numbers are Whirlpool parts that can likely be purchased from a variety of on line or local parts stores.
Sep 26, 2009 | Kenmore Washing Machines
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series will not rinse pleave advise how to fix this problem
If the machine agitates, spins and drain ok I would try different cycles and if some work and some don't change the timer. Timer is model 3951166 and runs for around 112 dollars Availible here only: http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=11022422100&productCategoryId=0153200&brandId=0582&modelName=AUTOMATIC WASHER, COMPACT A/W&diagramPageId=00002&componentDescription=CONTROL PANEL&documentId=P0102319&backToLink=Return to Sub Components list
Nov 01, 2008 | Kenmore 22422 Top Load Washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
354 people viewed this question
Top Washing Machines Experts
