Question about Compaq Presario C700T Notebook
My computer beeps when it come on. So what may the
Configuration error
  • George Bill
    George Bill Jun 01, 2010
    They all beep, what is your doing that is the problem, does it no stop beeping?
  • 428 Answers
Please check this list What beet you receive? Its better that you could post the BIOS model.
Check this link
You can understand what kinda error you have in your configurations. If you see this on the boot time (after the POST* has run) that might be a problem with a hardware device. Such as a removable drive (atapi device - cd rom drive) or connectors.
Boot the machine and when you are in Windows: Start -> Run (or win key + r together) and type this in and enter. Eventvwr.msc In the event viewer window navigate to System. Check for Red X marks (errors) and Yellow ! marks (warnings). You will be able to find the problem in their as well. That is not guaranteed but there is a good chance of the message being logged by the Event Viewer. (Remember the time when you booted it. Log is sorted using time.)
We are ready to assist you further.
If you are able to solve the issue with the help of the post please rate the answer with a testimonial. Thanks for contacting Fixya!
Posted on Jun 01, 2010
Beeping on start up
The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
GuruAid
Apr 09, 2014 | HP Compaq Presario SR1830NX PC Desktop
Sc 5100 beeps on startup
These are EACH... DIFFERENT SYSTEM CONFIGURATION ERRORS at boot
Check that you have not changed any hardware/added any hardware and that these changes were/or have not TAKEN EFFECT yet
Power down system.... use CMOS RESET pin config jumper to reset your boot configuration(s) changes
Multi-"BEEP" error messages are usually connected to RAM CONFIGS. and I would suggest uninstalling ram chips..... but ONLY AFTER FULL SYSTEM "power drainage"!!!... i.e. pulling power plug from your PSU, removing system battery or unplugging it's terminal wiring mobo connector, and pressing the POWER BUTTON on your system
Jun 04, 2013 | Computers & Internet
System configuration data updated ERROR,--Need a solution I have a fairly new Gateway M-1625 laptop running windows vista 32 bit, sp1. I turned it on and beeped twice (beep, beep) and gave me an...
Got a backup?
If not, download a Linux Live CD. Boot your machine with it, save all your data to an external drive and then do a complete disk format and re-install. That will be quicker in the long run.
Not sure about that PC, but on Dell, for example, you hit CTRL-F10 (I think) at power-on and it gives you the option of reinstalling the OS from the recovery partition (wiping any unbacked-up data in the process).,,Gateway is probably similar.
The Boot/BCD issue means your 'Boot Configuration Data' is hosed.
Jun 07, 2011 | Computers & Internet
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
Maxdata tower computer : - when switched on bleeps 2/3 times and doesn't engage the mouse or the keyboard and the monitor shows " no video input ".Just no response and doesn't turn itself on...
BIOS Beep Codes
Whenever a recoverable error occurs during POST, the BIOS displays an error message describing the problem. The BIOS also issues a beep code (one long tone followed by two short tones) during POST if the video configuration fails (a faulty video card or no card installed) or if an external ROM module does not properly checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors, usually consisting of one long tone followed by a series of short tones. For more information on the beep codes issued, check the documentation for that external device.
There are several POST routines that issue a POST terminal error and shut down the system if they fail. Before shutting down the system, the terminal-error handler issues a beep code signifying the test point error, writes the error to I/O port 80h, attempts to initialize the video and writes the error in the upper left corner of the screen (using both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to the operating system.
I hope this helps.
Mar 14, 2011 | Computers & Internet
When i turn on mt pc it beeps 9 times and noyhing
What you are hearing is a "post error code".
The codes vary depending on the manufacture.
For instance if you have a Dell 2400 trying searching the web for "Dell 2400 post beeps".
Although I believe 9 beeps is commonly a CMOS error.
If so, you can try clearing the CMOS.
You will have to know how to get to the Computer BIOS screen to set things if you do clear/reset the configuration.
Jul 20, 2010 | Dell Dimension 4550 PC Desktop
Continuous beeping with only the on/off button lighting up
this sounds like a configuration of the electronic problem. error e90 there are at least 9 beeps . can be badly connected wires particularily between main board ond front display board but usually ends up with a new main electronic (£120) also configuration is a complicated operation.
Jun 12, 2010 | Zanussi FLE1416W Front Load Washer
Firsty my ibm x 236 server is showing 162: configuration error than Re-=booting due to unexpected NMI at F000:FF54
XSERISE 235 TYPE 8671J
1,NO VIDEO,NO BEEP
2,PCI-X SLOT5 POWER LED ON BUT IT HAVE NOT BEEN ABSENT
Jan 20, 2010 | IBM X236 Server
Pc beeps 4times y?
4 short beeps
Your problem could
be a bad timer. The system timer failed to work properly. It will
require motherboard replacement.
1 long and 3 short beeps
Memory test failure. An error has been detected
in the memory over the first 64K. Try replacing the memory, and if
that doesn’t do it, the motherboard.
Beep codes are the beeps you hear from the
PC speaker when you turn on your computer. They are your computer’s way of letting you know what’s going on when there is no video signal. These codes are programmed into the BIOS of the PC.
Nov 10, 2009 | Dell Vostro 200 Desktop Computer
Ibm2366
ok here it is it is a auto repair sys from lenovo
This page has automated features! You can use the automated features on this page by installing a special, free plug-in. This one-time installation will not affect your computer's performance or compromise your privacy or security. fw.gif Install the automated content plug-in
chat.gif Just relax and let Lenovo Experts Live do it for you. Buy it now! New!
Some of these steps may not apply to your computer. Test for system startup after performing each step.
Select your symptom from the following list or continue to the Need more help? section:
Mar 24, 2008 | IBM ThinkPad T30 2366 Notebook
Compaq Presario C700T Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
