Fan number 2 over heating. Lost picture and sound
  • 8,617 Answers
Whats the model number of your set. I am usually able to help with DLPs . But need the model number in order to even begin to give any suggestions
Posted on Apr 09, 2008
SOURCE:
Electric fireplace
Heat and fan work fine for me, but the fire design for the logs and the wall wont turn on. I also lost the remote for it.
Jan 15, 2014 | Heating & Cooling
Lost heat fan still blows cold only and car overheating
Sounds like a possible water pump problem with the over heating part. About the heater only blowing cold you may have to get it "recharged"
Feb 28, 2013 | 2004 Chevrolet Aveo
Model KV-24FS120 lost picture and sound while on
Hello
The chroma jungel IC of your set is damaged
Mar 05, 2012 | Televison & Video
My thomson projection tv serial number atn706327 keeps cutting off every 5 minutes the fan stops and the picture goes away could you help please
This sounds like the protection circuit operating. With projection TV's, the cooling fan is essential to prevent damage from overheating. The fan contains a pulse generator to indicate rotation. If the pulse stops, the protection circuit will turn off the set. 5 minutes may be how long the fan takes to seize when it warms up. Also possibly heat sensitve parts along the cooling path covered with dust causing heat sensors to operate.
Jan 19, 2011 | Thomson Televison & Video
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
42 inch LG Plasma TV - Lost picture
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Apr 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
Televion was purchased in 2002 picture was sharp
Need more information.
Are you connected to an antenna?
Did the stations in your area go digital? (DTV converter required)
Mar 02, 2009 | JVC AV-27530 27" TV
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Sep 16, 2008 | LG 50PX1D 50 in. Plasma Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Ekse
