Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Air flow failure indicated on heater
I have a Jandy lx400 gas heater and it keeps shutting down showing "air flo sw" on the readout. I have checked the switch and it closes when the blower is running but the unit still fails. The company that installed the unit says it could be the fan motor or even the display board which they say costs 900 dollars. Any help?
    Problem Solver:
  • 3 Answers
Mine does the same. Sounds like you checked the air pressure switch, but the high temp switch and bad airflow can also cause this problem. Check the two white wires that lead to the heat sensor vent drain tube exits. Make sure the spade connectors aren't shorted. Try testing the temp sensor like you did the pressure switch to make sure the circuit is properly closing when in use (or use a temporary jumper to bypass as a test.) Check the bottom of the pan for any dust or crud that could block the airflow below or around the burners and last of my options- increase clearance around the unit to aid air flow.
Posted on Mar 06, 2011
LAARS LX250N-L error code AIR FLO SW and sometimes a HI LIM SW cannot locate the source of the problem?
hi limits are located under where the pipes go into the heater if corroded replace if wires bad replace to test you can jump them at the board only testing if left jumped heater could catch fire
Jun 29, 2015 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Air Flo Switch on
see if hose clogged or hole or collapsed
Jul 14, 2013 | Jandy LAARS LX250 - PROPANE, DIGITAL...
Jandy lx400 not igniting
clean flame sensor if dirty it will keep shutting off not sensing the flame
Feb 28, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
HI LI SW
check hi limits by plumbing can jump to check
Jan 17, 2012 | Jandy LAARS LX400 - NATURAL GAS, DIGITAL...
Was working fine and this week my jandy turns off as soon as turnse on and then display , service, air flo what that can be
Service-air flo, is telling us that the combustion fan is either not able to blow enough air either due to a blockage, or a fan failure, OR the air switch that detects this feature has failed, OR the rubber tubing used to connect the air-switch to the blower assembley is burned, or cracked.
Follow the tubing from the blower to the air switch to find it, then check the condition of the tubing. Replace if broken, burned , or cracked. If this is not the problem , it gets much more involved after this, and you must be familiar with a multimeter and know the internal electrical operations of the heater to troubleshoot it.
Id check the tubing, and call a certified Jandy tech if the problem persists.
Apr 11, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Laars LX400 Air Flo SW Error
is fan coming on if not bad fan motor also check pressure switch if 24 volts both sides that's ok make sure air flow switch hose is ok
Sep 09, 2009 | Teledyne Laars Laars Lx Pool Heater /...
I get a message saying Hi Lim SW when trying to heat my spa. What does this mean?
hi limit switch heating unit getting too hot what type of heater are you using
May 09, 2009 | Jandy LAARS LX400 - NATURAL GAS, DIGITAL...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
1,045 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
