Question about SanDisk Sansa m230 MP3 Player
It is in a pause state. The battery is fine. I
It is in a pause state. The battery is fine. I was told that it has to be re set
  • 2,418 Answers
Posted on Jun 01, 2010
Cmos reset
I have not specifically worked on this make/model of computer.
Technically, you cannot reset this ... I think what you are asking is how can your modify the settings. Typically one would press F2 or F8 or F11 to enter the setup during the boot process. It may be a different F key, it should flash on the screen when you boot.
You could disconnect the battery back up if you can locate it. ..This will remove any custom setting, but will not let you get back in to change it unless you find the correct F key to press.
On the other hand ... there are no more than 12 F keys. You should be able to find the proper one.
If this doesn't work, you should go to www.fujitsy.com/support for assistance.
Thanks for visiting today.
Jan 31, 2011 | Fujitsu Stylistic ST5112 Tablet PC
Green light comes on
Most Mitsubishi sets have a feature known as error code operational check. First up unplug the set and replug it. Press and hold the "Device" and "Menu" buttons for 5 seconds. You wil see a series of blinks a 1/2 second pause and another series of blinks. COunt the blinks before and after the pause and let me know. If its an issue other than power supply then you should get an error code. Power supply is the only thing that the operation check does not check.
Jul 06, 2010 | Mitsubishi WS-55805 55" Rear Projection...
I am getting A message which says "pause by temperature when the phone should be charging. What does this mean the phone is new.
It's normal with many phones. It's just stating that the phone is taking a brief rest during charging to avoid overheating. It's usually a hot battery rather than a hot phone, and it's most common in warm climates, or on hot days or if the battery is undergoing it's first full recharge.
May 20, 2010 | O2 Samsung SGH-E250 Cellular Phone
Is there a Fax modem available to be connected with scanner, copier and printer (three in one already with us.)
your unit has a fax installed in the unit.
Look at page 29 in your manual it will show how to send and receive a fax.
send a fax page 29
receive a fax page 32
print reports page 33
feature purpose
1 Phone Hook: the green LED in the shape of a phone indicates that the fax
line is in use when lit.
2 One-Touch Speed-Dial Buttons: use to access the first 6 speed-dial entries.
3 Auto Answer: when the green light is on, fax transmissions will
automatically be accepted.
4 Speed Dial: use to access speed-dial numbers that have been set up from
the front panel or with the HP Director software.
5 Redial/Pause: redials the most recently dialed number when in the ready
state. Inserts a pause (hyphen) when in the dialing state.
6 Keypad: use to dial fax numbers, and enter numbers such as the quantity
of copies or percentages when reducing or enlarging. You can also enter
text using the keypad for fax header, use speed dial entries, and specify
menu items.
7 Fax Resolution: use to set the fax resolution to Fine, Standard, 300 dpi,
or Photo. It will remain at the most recent setting until changed.
8 Start Fax - Black: starts a black and white fax.
9 Start Fax - Color: starts a color fax
Apr 27, 2010 | HP OfficeJet 6110 All-In-One InkJet...
No sound on motor storm and call of duty
you should try checking your sound setting this happened on mine then i went into setting and changed the sound output and it was fine after this
Jun 18, 2009 | Sony Playstation 3 (PS3) Console
Bios setup gone wrong
Since you didn't have any problem before the update, you could flash the BIOS (revert to it's original state) by shutting down, disconnecting all power (battery for laptops), then removing the CMOS battery for 5 or 10 minutes. Replace the battery, reconnect, then boot and your BIOS should flash and return to it's initial revision and default settings.
Apr 28, 2009 | Evga 896-P3-1260-AR GeForce GTX 260 896MB...
I was told that the OBD connection does not communicate info
Your best bet is to call the state and they will call the dealer and issue you a sticker. just call the state police and they will give you the number.
Mar 26, 2009 | 2000 Hyundai Elantra
Radio won't play
1) Go into the settings menu, go to FM settings, and make sure the FM Region is set for United States. If you are outside the US, change it to "World"
2) The radio might initially be set for Pause - to test this, turn to a specific radio station that you know you get, and press up on the clickwheel. The "block" icon underneath the radio station should now change to a play arrow, if indeed it was on pause.
Feb 01, 2009 | SanDisk Sansa Clip MP3 Player
I have a sansa clip mp3 but i can't turn on the fm radio. help
Jan 19, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa m230 MP3 Player Logo
185 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
