Question about Whirlpool RF368 Electric Kitchen Range
Baking filament is on - Whirlpool RF368 Electric Kitchen Range
  • Whirlpool Master
  • 43,501 Answers
Check out this tip about your oven not shutting off...
Electric Oven Problem Oven will not shut off
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
Posted on Jun 01, 2010
What are the usage of Nylon plastic filament used in 3D printing?
Nylon 3D plastic filament is extremely strong, lightweight, durable, and flexible filament used in 3D printers only.
Some of the other uses of nylon plastic filament are:
a. Machine parts.
b. Mechanical components.
c. Structural parts.
d. Gears and bearings, etc.
You can read the whole details and properties of this nylon filament from 3D Printer Filament
Aug 12, 2017 | The Office Equipment & Supplies
I have followed instrucions to the letter but my breadmaker is still not baking bread
If your breadmake is not working at all, try a different outlet. If that does not work, replace the unit. If the breadmake is mixing but not baking, you most likely need to replace the filament.
Jul 30, 2008 | Microwave Ovens
What are the drawbacks of duel filiment bulbs
1) one filament goes out and you have to change the bulb throwing out a working filament
2) if one filament breaks and falls onto the other one it can back feed that circuit ex. Turn signal filament falls on to brake filament so when the turn signal is flashing both brake lights flash.
Jul 31, 2016 | Cars & Trucks
How to to find PLA filament for 3d printers
You can contact the store where you purchased your printer. Either you should try amazon store to collect your 3d printer parts. Specially for PLA filaments you should try 3D Printing parts supplier, because they provide various types of PLA filaments like -
  • Ultimaker 2 PLA Filament (
    flexible white,red,transparent,blue,ultimate blue and others)
May 04, 2016 | SainSmart 3mm imported PLA Filament For 3D...
Clogged Extruder head
It is not unusual for the extruder to get clogged, especially when changing filament. the problem occurs when pulling the hot filament out and a tail forms within the filament channel. you can remove the stepper motor and try and pull the filament out. also unscrew the extruder tip and see if it will pull the clog out with it.
I use boiling water to clear the extruder head and it works nicely. if it is stuck in the filament tube you may need to pull the filament tube also to clear it out. it is also possible to remove the stepper motor and heat the extruder on preheat and push the tail inside the tube.
once this is done you should be able to "Load Filament" normally and once the new color id extruding your good to go.
May 13, 2013 | MakerBot Replicator 2 Desktop 3D Printer
I have a F & P wall double oven model OD302, first used 2 weeks ago, and the temperature, although set at 375 degrees, rises to only 122. All settings were used, ie. aero bake, bake, etc. The right...
The name F&P says it all! If there was any brand that gave the most problems, in products then F&P is the first on the list. With LG as the second
You say this is possibly a new installation of only 2 weeks. Don't dither around seeing if its a simple fix, get the installers/sellers back to fix it . It will probably need replacing as the control is faulty.
Thanks for using FIXYA
Dec 03, 2009 | Fisher and Paykel Ovens
I was heating my electric oven when one of the filaments popped and stopped glowing. now the oven won't get hot (enough) and i want to know if i can replace it myself or if i have to wait for my lazy...
You can DIY. The element will be about $40.00. Turn the power off to the range. Unscrew the element and pull it out carefully. Remove the wires. Reverse this order to re-install the new element.
Turn the range back on and bake me a cake.
Sep 22, 2009 | GE Profile JTP56 Electric Double Oven
Bottom filament on bake not working but broil and
FAULTY ELEMENT OR THERMAL SWITCH. HAVE IT CHECKED OUT BY AN ELECTRICIAN.
Sep 07, 2009 | Stoves 720EF Electric Double Oven
Kenmore 30425 Oven will not reach target temp
the ignitor is moast likley bad, look for a hot spot on the ignitor showing a open on the filament.
Dec 25, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Whirlpool RF368 Electric Kitchen Range Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
