Question about RCA D52W23 52" HDTV CRT TV
Colors on the screen are scatttered, mean I can see the red, yellow and blue lines.
  • RCA Master
  • 5,138 Answers
Go to menu then setup and see if you have convergence if not you have Blown Fuse FL231 it is located on right side of FBT flyback Transfomer there is 3 in a roll small brown looking caps But they are Fuses.06 it will be the one in the middle
Go to Partstore.com for part
Posted on Jun 01, 2010
Danco instructions
Umm, yeah I think so....
Nov 10, 2013 | Danco Home
My Officejet 6000 E609n printer doesn't print the correct colors. The red is printing yellow and the blue and green are a lighter version of what is on the screen. I have cleaned the printer head
This is not a cartridge issue. IT is Printhead issue. Since you have done the manual cleaning, it is now time to replace the Printhead.
Regards,
Suhail
May 14, 2012 | HP Officejet 6000 All-In-One InkJet...
Screen is showing all black things red
It sounds like your screen might be going bad. Normally there is no setting you need to be doing to adjust colors on your screen. There are some settings when you click Start/Control Panel/Display to look at your display settings, but these normally just control the color around the windows. For example the normal or default color for the strip that is at the top of your internet browser is blue but you can change it. I would say that when you boot your machine if the colors are not what they should be normally during the boot process, then your screen is going bad. You might try Opening a Word Document then type words such as Black, Red, Green, Blue, Yellow, etc. on different lines in the document. Then highlight the word and change the font color to match the word. This might let you see if your colors are true colors or if the screen is bad.
Mar 16, 2012 | HP Compaq nc4200 Notebook
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
Mar 02, 2011 | InFocus LP 250 Multimedia Projector
Red, yellow and blue bars going through the screen, what does this mean and how do I correct it?
U mean ur tv have colors shadows?Colors lines Red,Green,Blue misaligns don't line up to produced a solid picture?U have a 3D pic?All these are cause by a problems known as CONVERGENCE PROBLEMS.Ur tv the convergence board the 2 convergence ICS and some or all it resistors are dead.All these parts on the convergencce board,must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 15, 2010 | Toshiba TP50H50 50" Rear Projection...
Colors off. blue and yellow not lined up
try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Sep 30, 2008 | Televison & Video
Seperated colors
this is a common problem you have bad solder connections on the convergenc ics solder them back if this does not fix the problem then replace them k
Nov 03, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
How to adjust picture on projection tv
i have a 52" rca projection , and the screen looks like this ") (" on the sides can i do something to straiten it back out?
Aug 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
RCA D52W23 52" HDTV CRT TV Logo
93 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
