Question about Microsoft Xbox 360 Console
Yes my daughters xbox has a red ring.But when she takes off the hard drive it works..Any ideas
    Sergeant:
    Champion:
  • 452 Answers
Hard drive crashed. buy another one from ebay.
Posted on Jun 02, 2010
Xbxox original hardrive red ring
The "red ring of death" is really just an error code meaning that the console doesn't know exactly what's not working, but it knows it's broken.
If it's the hard drive itself that's broken, then any console that you plug the hard drive into will show the same error.
If you want to be sure, try taking a working hard drive and plug it into the Xbox -- if it's working, then it's just the hard drive that's screwed up.
Jun 24, 2012 | Microsoft Xbox Console
Xbox original hardrive
If you want to be sure, try taking a working hard drive and plug it into the Xbox -- if it's working, then it's just the hard drive that's screwed up...
My xbox had a red ring of death only one ring
This could indicate a hardware problem with your Xbox 360. Microsoft has a troubleshooting guide available here when you have one red ring: http://support.microsoft.com/kb/907536/en-us
Basically, you need to disconnect all cables, remove the hard drive or memory units, and turn the Xbox back on. If it works then, it could be a problem with the hard drive or memory unit you're using. If that didn't fix it, your Xbox will probably require a repair. Before requesting a repair, however, wait 24 hours and try the Xbox again - the problem could possibly fix itself.
Jun 01, 2011 | Video Game Consoles & Games
Hard drive has red ring can we replace with any hard drive?
...HDD has red ring? No, you cannot replace it with ANY hard drive, it needs to be a microsoft xbox 360 hard drive
Dec 30, 2010 | Microsoft Xbox 360 Halo 3 Special Edition...
Xbox 360 3 red rings no action taken yet
its called the ring of death.get.grab some towlels remove your hard drive. DO NOT UNPLUG YOUR CORDS!wrap the xbox 360 with your towlel with two towlels and wrap it tight.keep it in there on for 20min then you bring it out then it should be trun off because it over heated then you want to cool it down saw 20min again then put back your hard drive.
Dec 12, 2010 | Microsoft Xbox 360 Console
Got a green light in the centre and bottom rt is red,can`t do a thing with it,any ideas?
When only 1 of the 4 green lights that are located around the start button flashes red and the screen flashes an error code number, it means that you've got the Xbox 360 1 red light message.
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
once you have found out if its the hard drive or the dvd drive then this is the part that needs replacing.
you will either need to get someone to do it for you or if you have some idea what you are doing then it is something you can do yourself, always check to see if you have any warranty left and if you do take it back if not then you will need to pay someone to do the work for you.
if you are doing it yourself then take it from me its not easy taking the case off let alone changing the parts so if you are going to do it yourself use google and fine an xbox 360 repair guide and this will then give you step by step instructions on taking the case off and removing any parts you need to remove
Sep 16, 2010 | Microsoft Xbox 360 Console
One red ring, erra 68.
What you need to do is try using the console without the hard drive or with a different hard drive, one red ring means a hardware failure, and the error code e68 is in relation to the hard drive. If using the console with a different hard drive, or none at all doesnt work, ensure that the fans are working as they often also cause the e68 error and a single flashing red light.
I hope this helps. Good luck.
Sep 03, 2010 | Microsoft Xbox 360 Console
Rings of death
problem with hard drive get a new one or take it out then put it back in and it might work but getting a new one will work ofr sure
Oct 02, 2009 | Microsoft Xbox 360 Console
Red ring of death
It means "general hardware failure", so it could be any number of things. Its like a check engine light except when it comes on , it means something doesnt work. The only way to fix it is to send it off to xbox. Call 18004MYXBOX and they will send you a prepaid shipping label and a box and will get it back to you within a few weeks. Your xbox should be covered under microsoft's warranty so it shouldnt cost you anything. Removing the hard drive wont fix anything because the hard drive isnt needed for the xbox to operate, so if it failed the xbox would be fine but wouldnt be able to retrieve the data off it.
Oct 20, 2008 | Microsoft Xbox 360 Console
One Red Ring
This is usually the ANA or HANA chip.It controls the video output.Not good.
Jun 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
