Question about HP LaserJet 3055 All-In-One Printer
Describe your hp laserjet 3055 comm error 413 Problem. someone was trying to send and I got a report saying it was a "comm error 413"
5 Suggested Answers
  • 138 Answers
SOURCE: Hp laserjet 3050 fax report
The error 244 results from a fax machine communicating and trying to 'Poll" your fax. (receive information you have loaded into the fax memory for all to receive) The error comes in when your fax has no information or is not set up to be polled.
Look in your menu for the "ECM" setting on the printer menu. If this error is getting persistent change the ECM setting to the opposite of what it is set now. More than likely your fax will say ECM=On, change to off.
If you have problems locating where the ECM section is, print a "settings report" or "printer menu".
Hope that helps you.
Posted on Sep 05, 2008
AtlasIT
  • 72 Answers
SOURCE: someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
Posted on Mar 29, 2009
  • 14 Answers
SOURCE: HP Laserjet 3055, can't rec faxes
From the service manual:
The user of the remote machine has pressed the Stop button on that machine, which caused the session to be prematurely terminated.
-Or-
The remote fax machine identified a feature incompatibility between the two machines and has terminated the session. For example, the product tried to initiate polling, but the remote machine did not support this mode of operation."
With this recommended fix:
"1. Confirm that the remote user is not inadvertently attempting a poll transmission from the product, instead of transmitting to the product. This mode of operation must be specially configured on the product. If poll transmission from the product is the appropriate mode of operation, confirm that the product has been configured for this operation.
2. Reconfigure the local fax machine to use different configuration settings, change the ECM setting to the opposite of the current setting, or select a slower reception speed."
My vote: it's a feature incompatibility and I would go for solution #2 first.
If thisd is happening with every fax to every number, there is a chance it is part of known problem with this model. I have had to change out the formatter board on several 305x printers the l;asty couple of months, and all of them were covered by HP's warranty or a tech bulletin. If the problem persists after trying the adjustement above, call HP tech support (1-800-HP-INVENT) and convince them that they need to get it fixed. The formatter is easy to replace: pop off the left cover and remove 4 screws and a lot of cables, so unless they ask you to take it to an HP ASP, you should be able to fix it yourself.
Posted on Jul 01, 2009
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
Fax rec 2-3 pgs OK, then disconnects and gives Comm Error
These errors mean that the communications have failed, and can mean that the receiver at the other end has terminated the call prematurely.
If the problem occurs with the same destination, then the receiver fax may be the problem.
If the error persists try disabling ECM
Feb 04, 2010 | HP LaserJet 3055 All-In-One Printer
3055 trying to fax getting COMM. Error?
It's probably your phone-line that causes the problem. The fax-module in your machine needs a 100% analog phone line. HP garantees nothing when using IP/ISDN/PABX-lines. Try lowering the baud rate, turn off JBIG compression and error correction mode, but if the problem remains, you better replace your phoneline.
Jul 23, 2009 | HP LaserJet 3055 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Someone is faxing me iam getting commerror283 how to fix it
Hope this helps!
Mar 29, 2009 | HP LaserJet 3055 All-In-One Printer
Stopped Receiving
use the print menus option in information, it should show the menu path settings
Feb 09, 2009 | HP LaserJet 3055 All-In-One Printer
Sep 02, 2008 | HP LaserJet 3050 All-In-One Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
170 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
