RCA Home theater Television P46725SK will not cut on.Power button blinks when trying.
  • 8,617 Answers
Is there a pattern to the blinking? This may be blinking an error code that is indicating the nature of the problem. count how many times it blinks, and wether you hear any sounds such as clicking.
Posted on Apr 09, 2008
Try to turn on via remote or button on set. Only a green flash on front. Nothing else. Can I fix it?
About 435,000 results (0.80 seconds) Search Results
    3 Ways to Program an RCA Universal Remote - wikiHow
    www.wikihow.com > ... > TV and Home Audio > Television
    wikiHow... Universal Remote. Are you tired of juggling three or four different remotes just to control your home theater setup? ... Log in via ... Turn on the device you want to control. ... Press and hold the button on the remote that corresponds with the device.... You will need to try another method in this article to program the remote.
    How to Program an RCA RCR312W Remote: 15 Steps ...
    wikiHowHow to Program an RCA RCR312W Remote. ... Log in via ... Press the PLAY buttonevery five seconds until the component turns off. ... If component does not respond or has limited functionality, codes in a different block list can be tried until you find the code that allows the remote to .... Set Up a Home Theater System.
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... You can always contact us via our Facebook page or tweet us ... Hi my TV is anRCA model # RLDED3258A-B I have tried 73 codes from Universal .... I have tried toset up my tv and home theatre with the Rogers remote but no luck...
    RCA TV: input channel/s-video - ecoustics.com
Jan 19, 2016 | RCA Audio Players & Recorders
When i cut my system on it cuts back off mu-ti-ki 5disc cd changer
There is a short in the amp that needs to be repaired before the unit will power on normally.
Mar 19, 2013 | Sony MUTEKI HTDDW1600 Theater System
Where can I purchase a mother board for the RCA Home Theater TV model type P46725SK?
Try website like Tvrepairworld.com have many DLP RCA tvs refurbishes boards parts,should have the mother board too.
Jan 13, 2011 | RCA P46924 46" Rear Projection Television
How do you connect the speakers on to your flat tv. I read it on the manual that u have to use HDMI, but i did. It still won't work.
This model has speakers. If you are trying to connect external speakers i.e. a home theater system, receiver or a sound bar you have a couple options.
This television only has hdmi inputs so you cannot connect the external speakers with hdmi cables. The television would have to have and hdmi output.
Now in order to use hdmi you would have to connect all your devices to the home theater and then go hdmi out from the home theater to one of the two hdmi inputs on this television. Then you would leave the television on that hdmi input at all times and switch devices with the home theater remote.
All the devices would be connected from their respective outputs to a respective input on the home theater.
Another option is to connect a fiber optic cable from the television to the home theater.
Another option would allow for stereo sound but not the higher quality surround sound. You can connect from your televisions red and white RCA outputs to the RCA input on the home theater.
Dec 30, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Reset button on 52 in rca rear p52940 home theater projection television located
this set does not have a reset button if there is a system lock out unpluging it for 3 or 4 mins will reset when pluged back in
if that does not help try trouble shooting the set ck the ac fuse and so on
Oct 24, 2009 | RCA P52940 52" Rear Projection Television
RCA RT2870 home theater system 'welcome' screen
Well, I just returned the unit. RCA replied with the following solution:
Let the unit sit with the AC power cord out of the wall for a couple of
hours. Then hit the power button 10-15 times (with the AC power cord still
out of the wall socket!) and then try again.
Oct 02, 2009 | RCA RT2870 Theater System
I keep getting the 'rear check' message on the tower panel display and all cables are connected what could this be this is on my new HT-TXQ120 DVD HOME THEATER SYSTEM
With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
Note: You can release the REMAIN button when the POWER LED blinks blue.
With the wireless module turned on, use a ball point pen to press the RESET button on the back of the wireless module. The POWER LED in the front of the home theater blinks two times.
Turn on the home theater. The LINK LED on the front of the SWA-3000 changes from red to blue, indicating the wireless module has connected to the home theater.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 29, 2009 | Samsung HT-TXQ120 Home Theater System...
Rca big screen
Does the power led blink, when you press power? Please respond to this post and I will try to assist you with the problem. Please respond to this same post when replying
Jul 31, 2008 | RCA D52W19 52" Rear Projection Television
Rca home theater problem
The trouble is the front panel buttons,unplug the unit and remove the back cover,just below were you removed the top screws,you can look under and see the top of the tubes,there is a small board in front of the middle tube,unplug the right top cable off this board and you can use your remoten till you can get it serviced
Oct 01, 2007 | RCA P61927 61" Rear Projection Television
Swa3000
  1. With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
    Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
  2. With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
Feb 14, 2007 | Samsung HT-Q70 Home Theater System System
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
