Question about Samsung LN-S4695D 46 in. LCD HDTV
Samsung 46" LCD vertical lines
I have a Samsung 46", LCD TV model# LN-S4695D The tv has vertical lines that are evenly spaced all across the screen. If I take the back off and point a fan at it, that seems to help a little. If I unplug it for a while that seems to help as well. The lines are usually red, white, and blue. If I bring up the menu the lines still show up behind the menu screen. The lines are not visible when there is no input going into the TV, just the normal blue screen. (No DVD player or cable plugged in) It has been suggested to replace the power board, T-con board, and main input or signal board. I am not sure what to do. Any suggestions???
  • 192 Answers
SOURCE: LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Posted on Jun 03, 2007
SOURCE: Broken Screen
Replacement LCD panel is on Ebay.
Posted on Jul 21, 2008
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
  • 610 Answers
SOURCE: LN-T4671F 46 in get loud clincking sound when tv
power supply is probably about to fail. will probably start to cycle on/off by itself.
Posted on Oct 28, 2009
  • 117 Answers
SOURCE: I have a LN-T4061F Samsung LCD, I'm seeing
most of the time this is the ctrl board its like a graphic card tells the screen what to show,but the cable from that goes to main board sometimes this is the cause of lines/open it get no of control board it has a 30 pin thin lead going to main board and google it easy to replace plug n play
Posted on Nov 10, 2009
Green vertical lines across screen
It will be best to contact the authorized service center for Samsung in this case. They only can provide the component.
Nov 30, 2013 | Samsung LN-S4695D 46 in. LCD HDTV
Samsung LN-S4695D LCD WON'T TURN ON BUT POWER LIGHT IS ON ?
I would recommend you get a professional diagnosis. There is high voltage present in the set that can harm you. Being that you never messed with a TV, you could possibly cause more damage to your set. These flat panel TV contain sensitive circuitry. What you are describing sound like a fault with either the power supply or main board.
Dec 01, 2012 | Samsung LN-S4695D 46 in. LCD HDTV
LN-S4695D replacement stand
do you by chance have a pic of your old broken neck? I have a few Samsung pedestals in stock.
Have a Samsung LNS4695 DX LCD about 3 1/2 years old. When powers on will take about 5 secs and then picture but has thin, multicolored vertical lines. After turning off and on a few times, picture is...
yes this is due to bad caps I have replace dozens of caps for samsung tv's you can do it your self or have some body do it for you or ship the power board to me
Sep 04, 2010 | Samsung LN-S4695D 46 in. LCD HDTV
Red dots across the screen
Please check the power supply board, if there is any Pup-Up electrolytic capacitors, please replace them.
May 25, 2017 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN-S4692D - Vertical lines (>15) & static on screen
this sounds like a scan board gone ,, if you check ebay youll see two things,
1, other tvs for sale with the same fault (It might give you a clue to the fault ie , which board )
2, the same tv as yours with a broken screen ,
i dont know how good you are with taking things to bits but i personally would buy the tv with the broken screen and start swapping over the internal boards ?
Have you checked your home insurance policy for broken tv,s
it may have fell of its stand when you were'nt looking?
May 16, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Vertical Lines and Ghost image then powers off
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts..
Mar 24, 2017 | Samsung LN-S4695D 46 in. LCD HDTV
Broken Screen
Jun 28, 2008 | Samsung LN-S4695D 46 in. LCD HDTV
VERTICAL LINES AND THE COLOR CHANGES
are the colored lines all the way across the screen? with no video even menu does not show up i would say you have a bad panel take it back to the store
Oct 22, 2007 | Samsung LN-T4671F 46 in. LCD Television
Samsung LN-S4695D 46 in. LCD HDTV Logo
422 people viewed this question
Jerry Greenberg
Jerry Greenberg
