Question about Mr Steam Mr. Steam Allegro Sauna Model A200 MST-A200
Water will not heat
The system activates ,fills with water, but no steam.
    Scholar:
  • 130 Answers
Check the elements with a continuity tester. check the thermocouples, they may be in an open position preventing the elements from getting power
Posted on Jun 06, 2010
Cannot get steam to come out of my delonghi prima donna XS coffee machine
Could not find why but maybe if you go back over the scaling procedure and steam procedure there might be something you missed.
Please note! If "Energy saving" is active, you may have to wait a few seconds before hot water and steam are delivered.
Steam delivery 1. Make sure the hot water spout is attached correctly (fig. 7). 2. Fill a container with the liquid to be heated/frothed and immerse the spout/cappuccino maker (D5) in the liquid. 3. Press the steam ( ) button. After a few seconds, the steam to heat the liquid comes out of the cappuccino maker and "STEAM" is displayed. 4. When the required temperature is obtained, interrupt steam delivery by pressing the steam ( ) button again. (You should not discharge steam for more than 3 minutes at a time).
http://www.delonghi.com/Global/InstructionManuals/EN/EN-PrimaDonna-ETAM36365M-im.pdf
customer support
Customer Support
Nov 25, 2015 | DeLonghi Coffee Makers & Espresso Machines
Low power from steam mop
Try to be a little more vague! Model? Age of steamer? Rate of use?...Try a couple of drops of vinegar in with the water you use to fill your steam mop. The heating element that heats the water is probably oxidized, especially if you use tap water to fill it. You should only use distilled water in these mops. Some lower end steam mops have a handle that compresses, as you push the mop forward, which essentially makes the mop steam more, the more you "pump" the handle. Hope this helps!
Jan 29, 2015 | Vacuums
I have a home steam heating system in my home, I noticed a hole smaller than a pea,and my heat won't work, how do I fix this problem
If the hole is in the bottom of the radiator, you may have lost the water needed for steam. The boiler has a fill valve to add more water to produce steam. There's usually a glass gauge. P.S. you have to fix the hole,also. Try a metal epoxy.
Simac evt 100 steam cleaner
Try taking the steam head apart and cleaning. If difficult to remove, fill a basin with white vinegar & a small amount of water and let it soak to remove the built up deposits in the system. Remember to only use distilled water when steaming to avoid build up.
Mar 30, 2014 | Vacuums
How do I fill the water resevoir for the conair steam mist curling iron??
HOW TO FILL THE WATER RESERVOIR: 1. Remove water reservoir cap (the one at the end point of the hot part) and unscrew steam activator in order to fill. CAUTION: Steam activator is very hot while in use. Do not touch. 2. Fill reservoir with water. 3. Place cap back onto unit making sure water is not leaking out. NOTE: Fully immerse the wick and wick holder in water for at least 15 seconds before use.
Jun 26, 2011 | Conair Health & Beauty
Steam Shower shuts down immediately now.
probably scale build up from tap water unfiltered. Scale caused by mineral deposits will affect safety systems and auto cut offs in the unit
Sep 13, 2009 | Mr Steam Mr. Steam Commercial Steambath...
Espresso machine loses steam than recovers in minutes
It sounds like a heating element issue. Those elements look like a single unit but are actually made up of 2 or 3 independent heating coils - one may not be working. So, you're only getting 1/2 to 2/3 heating capacity, which isn't noticeable until the machine is under heavy steam load.
Dec 11, 2008 | Nuova Simonelli Program VIP Coffee Maker,...
Steam sauna (mr Steam ms400tc1). Unit fills up then allows water to exit via steam head without heating up to steam. Unit should stop water entering heating tank when full, heat up to steam, then allow...
If that unit has a steam valve I'd suggest checking it to ensure it's not stuck open. If it is, the steamer will not build pressure also. Should be a gauge for tank pressure that will show if it has built up pressure. If the valve is stuck open, it may certainly just dump water instead of steam. It's possible the water level sensors are allowing too much water into the tank, and as a safety it dumps. I've changed steam valves quite often due to the amount of heat they have to deal with.
Sep 16, 2017 | Heating & Cooling
Mr Steam Mr. Steam Allegro Sauna Model A200 MST-A200 Logo
142 people viewed this question
Top Mr Steam Electrical Supplies Experts
BJ Russell
Hippy_dd
Are you a Mr Steam Electrical Supply Expert? Answer questions, earn points and help others
