Question about Panasonic TH-50PX60U 50 in. Plasma HDTV
Sound won't work...
The only things on the physical TV that works is the power...Otherwise the TV/Video , channels and volume don't work.. From the remote only the power and channels change.......Can't get into the menu, can't change volume.
What can I try? Already have tried unplugging for awhile and replugging it in, that hasnt worked. It's not worked for about a month.
Katie
I called Panasonic Service and got an answer that worked for me--the unplug for five minutes that, apparently, didn't work for you. Panasonic told me that if it happened again, call them back and they could send me some type of plug-in card that would fix the "lock-up" problem, of which they have just recently become aware. (I was really impressed with the quality and friendliness of their service, by the way.)
Posted on Apr 12, 2008
  • 81 Answers
Can you go to the input mode and change it?? try that and make sure everything is turn on ( dvd, cable box, sat box, etc.)
Posted on Apr 09, 2008
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
My channels don't come in anymore. The guide comes up but no channels. Yes, the box is on. I didn't touch the settings on either it or the tv. I did reset everything and it didn't help.
Boxes can be a pain. Do you have a Video or Av button on the box that you can try and press.
Sounds like TV is set up Ok otherwise the guide image would not go on the screen. My mother in Laws digital box often gives me curry. (first thing to advise - never buy mother in law technology - the old bag will call your cell phone at all hours to figure out why it isnt working - second words of advise - never give mother in law cell phone number)
First thing to do simply unplug the bloody thing from the power socket to reset it.
Failing this It is often the video mode outputs on the box that are not set up properly. Even though the startup image and guide comes on unless the correct video image output is set up properly you will not be able to view the TV.
Jun 03, 2011 | Televison & Video
While watching TV we got sound and the TV stoped working.. No picture.. when we turn on it makes noise..but no picture..what could be the problem.. Do you the lamp is gone.. or some other problem..
IT may because of over heating and more alternate current.....the picture tube is gone away from which video is not seen and speakers are tered due to high volume it seems so but do take that channel you are watching is consists of a channel.....otherwise without channel it ll make sound possibly......
Jan 20, 2011 | Sony KDF-E55A20 55 in. LCD Television
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Powers on will not change channels or video inputs
Is your remote programmed properly? If it is a universal remote, try setting it to one of the different codes for your brand. Sometimes the power and mute buttons and things like that are the same for all different types of a brand, yet all of the channel and volume things are different. If it's the remote that came with the TV, then I would try to get a replacement, as it could be faulty. Hopefully this problem is with the remote, and not the TV. Find if this is the case by using the volume/channel buttons on the TV itself. If they work, then you can be reasurred you don't have to call the TV repairman, and you will probably be able to fix this problem yourself.
Mar 16, 2008 | Televison & Video
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Panasonic TH-50PX60U 50 in. Plasma HDTV Logo
172 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
