Question about Maytag M6X08F2ACOM Air Conditioner
I cant change the tempeture no lower then 66 degrees
Its frustrated now
Replacing upper intake gasket 2003 E150 4.2l
Remove the 12 bolts that hold the intake to the lower section and disconnect all the hoses and linkages. Replace the lower gaskets and torque the manifold in a radiating sequence in this order.
stages to tighten
stage 1 - 59 inch pounds
stage 2 - 66 inch pounds
stage 3 - 90 degrees
Sep 17, 2012 | 2003 Ford E150
Lower thetermostatv temprature to 66. it's set to 77 right now and doesn't go lower
Question is not clear.
Add a comment and say what you want to do.
You have 240Volt electric water heater.
Lower thermostat is set as low as it can go at 77.
But you want water temperature set to 66?
First thing to remember is that water heater thermostat settings are approximate since they read temperatures through the steel tank wall.
Second thing is that thermostats for electric water heater are generic, and are not made for lower temperature range settings. This is probably since most people complain that water is not hot enough.
I'm looking at a generic lower thermostat from Lowes right now. The low temperature setting is 90 degrees F.
Looking at some older thermostats from a drawer right now: one does not have a lower temperature mark, the other is a Reliance with low temp of 95, the old craftmaster goes down to 80.
So I don't even have a thermostat that goes as low as the one you have, except for gas water heater thermostats that traditionally can be set to 50 degrees for vacation mode to prevent freezing.
More thermostats can be seen on following link:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Jul 12, 2011 | White Rodgers 0754-1 Electric Water Heater...
What degree should I keep it on? 66 or 79? I can't find the manual
79 will mean that your house will be 79 degrees inside, I would think you would rather 75 or lower number. The lower the number the colder you want the room to get and the harder the AC will have to work for you.
Jul 07, 2010 | Fedders A6D24E7D Wall/Window Air...
Manuals
thats probably 260c , 200c is about 400f.
Nov 22, 2009 | Whirlpool Ovens
Ext tempeture on a/c display show exterior tempeture at 50 degree;s but it is in the 90's
in the grill area is a sensor it is very comon for the sensor to go bad ,check it to make sure it is clean of debrie (bugs) un plug the sensor see if the temp changes if it does thats most likly your problem, you can test the sensor with a ohm meter by warming it up while reading the resistance
Jun 12, 2009 | 2003 Chevrolet TrailBlazer
Amana ACS3350AS stove temp in oven stays at 100 degrees . takes 1/2 hour to light or get to set tempeture. replace senor temperature and control panel. what should i do now
We had the same problem and it turned out to be a burned out lower heating element. Only the top one was heating and I could never get it over about 150deg or so.
Mar 16, 2009 | Amana ACS3350AS Gas Kitchen Range
Hot air blows unless the temp is turned down to 66 degress
well ? Does It get cold @ 66 Degrees? And If so.. Aint 66 degrees cold?
Mar 15, 2009 | 2004 Honda Odyssey
Oil change
if the caris to be driven in a tempeture of 60 degrees and below all the time,use a SAE 5W-30 oil,if in a 0 degree to100+ than a SAE 10W-30 oil should be used.good luck to u.
Mar 08, 2009 | 1998 Cadillac Catera
Maytag M6X08F2ACOM Air Conditioner Logo
21 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
