Question about Whirlpool LER4634J Electric Dryer
Dryer not spinning
My dryer stopped spinning. It's only 3 years old. Think it might be the belt? Is it easy to fix?
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryerDryer not spinning - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
DryDryer not spinning - 2_bing.gif="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 01, 2010
Testimonial: "Thank you so much for your help. It turned out to be the motor... too complicated for me to fix. Fortunately, I have an extended warranty. I was trying to save them a trip. "
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
My kennywood 90 series dryer about 10 yrs old
It could be a bad thermal fuse that is attached to the heating element housing. If it is bad, on most models it will not allow the dryer to start.
Oct 02, 2014 | Dryers
Frig. gas dryer agq6000es not tumbling
Do you hear the motor running? With door closed.
Most dryers will spin though a little hard to do so. If it spins VERY easy the belt is possibly broken.
If the dryer is several years old it Could be the belt.
Also check for a switch for the door, if there is one.
Door switch would shut off dryer when opened.
Nov 29, 2013 | Frigidaire AGQ6000ES Gas Dryer
Dryer is getting very noisy. Does this mean there is a problem ?
The most common reason for the dryer drum to stop spinning is if your drum belt has snapped or has been worn down completely. This is an easy fix and simply involves buying a replacement belt and feeding it through the pulleys and on the roller and then back around the middle of the drum.
The rollers could have worm out causing the drum to spin in a bumpy and noisy manner , these are the little circle shaped objects your dryer actually sites and can usually be replaced depending on how old your dryer is. The pulleys could also be broken causing problems.
The motor could have died after many years of use if the drum is not moving at all and if it is moving the motor bearing could be off causing to spin around very roughly and sometimes scratch against the sides of the dryer compartment.
Noises coming from the dryer when its plugged in and spinning could also be due to a huge amount of dust built up around the dryer drum. Sometimes cleaning out the inside of your dryer and returning the drum to the correct position can fix this problem.
Screeching noises are not a good sign and sometimes its a sign that you drum is slowly cutting into the sides of your dryer which could permanently put your dryer out of use if its continues.i think i will work out
Dec 16, 2010 | GE Dryers
My dryer won't turn. The motor runs when you push start but the drum doesn't turn. I can turn it by hand and it will run.
- The most common reason for the dryer drum to stop spinning is if your drum belt has snapped or has been worn down completely. This is an easy fix and simply involves buying a replacement belt and feeding it through the pulleys and on the roller and then back around the middle of the drum.
- The rollers could have worm out causing the drum to spin in a bumpy and noisy manner , these are the little circle shaped objects your dryer actually sites and can usually be replaced depending on how old your dryer is. The pulleys could also be broken causing problems.
- The motor could have died after many years of use if the drum is not moving at all and if it is moving the motor bearing could be off causing to spin around very roughly and sometimes scratch against the sides of the dryer compartment.
- Noises coming from the dryer when its plugged in and spinning could also be due to a huge amount of dust built up around the dryer drum. Sometimes cleaning out the inside of your dryer and returning the drum to the correct position can fix this problem.
Dec 15, 2010 | Dryers
What would make a dryer stop tumbling? It is about ten years old now. It turns on alright but just won't spin anymore. Its a MayTag so shouldn't it work forever! LOL
Probably just a broken belt. Unplug the dryer and open it up (PIX BELOW) clean out the dryer and inspect the wheels idler and blower cage.The belt is probably gone after 10 years. Here are some repair pix
Aug 28, 2009 | Dryers
Whirlpool Dryer wont spin
If it heats but doesnt spin, most likely the belt. May not be broke though. May have fallen off. Let me know if you need more help.
Dec 16, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
456 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
