Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore Elite model no. 795.75549401 freezer leak
I have a Kenmore Elite model no. 795.75549401 and its freezer seems to have a serious leak. The water goes right on the bottom of it, turns into ice and it doesn't let me open the door. I turned off the ice-making option first - it didn't help and the water (and ice) was there in 2 weeks. I shut off the cold water in the kitchen, but the water is still here pretty regularly. And each time I have to melt this ice, to clean everything and it starts again. What can it be due? Besides, I tried to solve this problem myself and I tried to open the back panel, but it's full of foam and it doesn't go off. What should I do to take the panel off?
I will appreciate any information about my problem, please.
Thanks
aborcass
  • 2651 Answers
SOURCE: water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Posted on Feb 23, 2008
SOURCE: Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Posted on Jul 22, 2008
  • 220 Answers
SOURCE: water leaking out freezer door--unit is still making ice
There is a shroud at the back of the freeezer. (Mine was a GE) but under the shroud is the evaporator coils and also a heating element to defrost the coils during the defrost cycles. Mine had the gutter underneath misaligned and the water went into the freezer and froze instead of going down the drain. I thought it was a ice maker leak until we found that. The weird thing is we had the refrigerator for about 6 years before it started leaking like that.
It has worked fine for about a year since that "fix"
Posted on Jan 06, 2009
  • 31 Answers
SOURCE: KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
maklean
  • 1665 Answers
SOURCE: Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas.
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer.
Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
Watch its operation more closely to see if any same symptom.
Posted on Jan 15, 2009
Side by side Kenmore Elite Refrigerator model # 106.56709500 Problem: water is not despencing, nothing is activated when cup is pressed up against button
Hi! I have a Kenmore refrigerator 106.56709500, and it does not cool on the fridge side. The freezer side seems to be OK since we still have ice. IS that I have to change the evaporator fan on the freezer side. Please advice.Thanks
Jan 11, 2011 | Refrigerators
I have a Kenmore elite bottom freezer refrigerator. The unit was made by Amana according to the first 3 digits of the model number (596.76253702). The unit leaks about a qt of water. It started as once a...
I have a Kenmore elite bottom freezer refrigerator. The unit was made by Amana according to the first 3 digits of the model number (596.76253702). The unit leaks about a qt of water. It started as once a month and is now leaking every 2-3 days. I brought the frig in Aug 1009. Any thoughts? Ishqbaaz Full Episode Watch Online
May I simply say what a relief to find somebody that truly understands what they are discussing on the web. You actually know how to bring an issue to light and make it important. A lot more people should check this out and understand this side of your story. It's surprising you're not more popular given that you definitely possess the gift.Ishqbaaz Porus Drama
Feb 06, 2018 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore elite Model #795 7554 2501 MFg date 2005-01. The water container behind the left door is leaking I need a replacement. Can you help
in trying to locate this model # with sears data base it didn't come up. i don't know of any kenmore that has a water container behind the left door . left door being the freezer door .. the water container is located in the botttom of fresh food side in the back behind the crispers . if thers a leak in the freezer door i would think that it a water line that is carcked or come loose .. mm hope this helps .. pls reck your model # and in needed get back with me ..mm
Oct 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
Water in Leaking in the Freezer
Hi, this sounds like a problem with a blocked drain. For full instructions on clearing the blockage from my tips click HERE if you have any other questions please feel free to comment. Mike
Dec 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a leak in my Kenmore elite refrigerator. I
Hi, Keep melting the ice until you see the drain hole uder the evaporator coil. You wil need to try and flush water through the drain to get it open. I like to use a baisting syreing.
Please let me know if this has helped you at all or if I can assist you further.
Thanks
Vic
Jul 18, 2009 | Refrigerators
There is water leaking from the bottom of the fridge
Hi!!! It seems that your drain line in the freezer section is plugged remove the bottom tray and check for ice or water if you do the unplugg your drain line with a hair dryer..good luck..
Jan 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
204 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
