Question about SanDisk Sansa e250 MP3 Player
I want to delete EVERYTHING
I want to start my mp3 player over COMPLETELY
okay there is no music in my Sansa e250 but everytime i go to my computer and in to the sansa file i still have music folders with no music in it and i cant delete them i tried many times and none of them worked so can someone help me
  • 8,596 Answers
Reformat
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
Removing songs
follow the steps below:
Check to see that the player is in MSC mode by going to the USB mode section in the "Settings" menu.
Plug the SanDisk Sansa MP3 player into your computer.
Click on the "Start" menu.
Click on "My Computer."
You will now see a drive for the device and one for the SD card.
Double click on the "Sansa device."
Select the music file you wish to delete.
Press "Delete" on your keyboard.
By bow, the music should have been deleted.
Good luck.
May 27, 2010 | SanDisk Sansa e250 MP3 Player
I want to redo my mp3 player how do i delete what i want and add the music i want?
if you want to delete everything on the device format it- my computer, right click on device format, start
or just open up the device through my computer then your device and search for the music files and delete and put what you want
Aug 03, 2009 | SanDisk Sansa e250 MP3 Player
Reformatted sansa e250 need help
When you format it, it deletes everything on the player. You'll just have to put everything back on it.
Jun 20, 2009 | SanDisk Sansa e250 MP3 Player
I have tried EVERYTHING and NOTHING is working for this problem
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Mar 31, 2008 | SanDisk Sansa e250 MP3 Player
Music will not play
For this problem you will first have to make sure that you Sansa is in "MSC" format under settings. Then connect it to your computer and locate it under "My Computer." Right click it and find "Format." When the screen pops up make sure it is NOT on quick format and hit okay. This should erase everything off of it. :) I had the same thing happen!
Mar 20, 2008 | SanDisk Sansa e250 MP3 Player
Music isn't showing up on my computer so I can't delete or update! =S
Using msc mode, use my computer and right click on the drive corresponding to the mp3 player, and select format. That should clean up anything that's causing problems.
As far as the player refreshing every time it starts, this is NORMAL, and it WILL take extra time since you have an additional memory card to scan.
Dec 24, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 keeps freezing
If you're checking that its empty in your rhapsody program, you might want to click on My Computer and then click on your Sansa mp3 player and then go into music files and delete everything. If u want to delete everything, including videos and pictures, you can go into your rhapsody account, plug in your mp3 player and right click, scroll down and click on "format" this will hopefully delete everything on your mp3 player...if u don't apply to any of these, well....sorry i don't know how to help.
Dec 08, 2007 | SanDisk Sansa e250 MP3 Player
How do i delete songs off of my sansa e250?
You can manually delete the music thru My Computer. Just click on the device name, and open the Music folder. If you dont have a Music folder, you need to enable hidden files and folders on your computer. Best of Luck.
Sep 23, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk e250 rhapsody
Cannot restore -must reload
May 26, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
you will have to go to the srichtonize thing nd right click on music and press delete then it will help you
Sep 30, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
21 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
