Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
THE FREEZER SECTION IS COOL BUT THE REFRIDGERATOR IS NOT.THERE IS BUILD UP OF ICE ON THE BACK PANEL. THE FAN RUNS CONTINUOSLY I HAVE ADVANCE THE THE HEATER TIMER TO DEFROST MODE. THE FAN STOPS AND AFTER A PERIOD OD TIME RESTARTS.WHAT PARTS SHOULD I REPLACE?
  • Whirlpool Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorTHE FREEZER SECTION IS COOL BUT THE REFRIDGERATOR - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 01, 2010
Model acd2234hrs amana is getting a lot of ice build up through outn the freezer all food in freezer has layer of ice on it
Check that the fan is running at the back of the freezer section. If it isn't, the freezer will continue to get colder but as the air is not moving around the cabinet, you get areas of ice buildup. The fan is usually at the top of the back panel, With the fridge unplugged, remove the panel in front of the fan motor. You can otherwise check if the fan is running by pressing the door switch whilst the freezer door is open. If the fridge is running, when you press the switch, the light should go out and the fan should start.
Nov 08, 2013 | Amana ACD2234HRS Side by Side Refrigerator
Kenmore refrigerator(model 10653606202) freezer is cooling, can hear the circulation fan' noise, also see defrosted water in the bottom collection pan. but the refrege is not cooling.
If the freezers is freezing everything and you can hear the circulation fan, maybe it is a defrost problem. Sometime ice will build up behind the rear panel in the freezer section that blocks either the chilling tubes to the refrigerator section.
You will need to remove the food from the freezer, then remove the shelves and inside back panel of the freezer. If you see a lot of ice, that is probably your problem. DON'T use water to defrost, either unplug and let it set with the door open or hurry it up with a hair dryer.
It also means your defrost assembly has stopped working and will need replaced, but the unit will work without it for several weeks before the ice build up redevelops.
Jun 07, 2011 | Refrigerators
Refridgerator does not get cool enough
Buttom freezer Sub Zero. Replacing evaporator for fresh food section.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Moisture problem in refridgerator section of Samsung RT30MBSW1
probably the defrost system is failing .. look in back of freezer / if you can ice build up the defrsot sistem not working . also the fan of fans could be running to slow. replace ment needed . . mm
Jan 07, 2010 | Refrigerators
Freezer working only slightly. Refridgerator not working at all.
If you have ice build up behind the panel inside the freezer, you most likely have a bad defrost heater. You can remove the back inside panel of the freezer. Take a hair dryer and defrost the ice. When the ice is gone you can inspect the heaters. If they are not fixed it will continue to happen. When the coils ice over, first the freezer will get warmer. The first complaint is that the ice maker stops working. Then the ice cream starts melting (Due to the sugar in ice cream, it has to be around 0 degrees to stay froze solid). Then the fresh food section starts warming due to the fans not being able to force air into the fresh food section.
Please rate solution if helpful. Thanks
Aug 19, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerator side not cooling
The fresh food section is cooled by the freezer section by forced air supplied by a fan. If you have air flow, check the temp inside the freezer. It should be between 0 and -10. If not look inside your freezer and see if you have ice built up on the back panel. If so you have a defrost problem that is most likely a bad defrost heater, a bad termination thermostat or timer. If ther is no ice then check your fan under the refrig. If you can hear the compressor running it should be turning. If this all checks out then you have a freon system problem like. Low Freon pressure or a restriction.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
No cooling in refridgerator
is freezer cooling?
a possible cause is build up of ice on the evaporator. take off the back panel in the freezer and check. also check the fan is working. if there is excessive ice build up, this can mean that the defrost system is not working. in any case, if there is ice build-up, carefully melt the ice off with a hairdryer
Jun 19, 2008 | Samsung RB215LASH
Amana 8 yr old side-by-side refridgerator/freezer
sound like you said a sealed system problem if compressor is running check the black coil under ref by the fan and see if it is warm if not you have lost freon just trash it then if it is see if fan in freezer is running if so pull back cover in freezer and see if coil starts to freeze if you have a ice block on coil then it is a defrost problem good luck
Dec 04, 2007 | Amana AFD2535DES French Door Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
96 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
