Question about HP DesignJet Z2100 InkJet Photo Printer
I get vertical banding with hp z6100 and all kinds of media. These are "tracks" from pinch rollers. Any help or suggestions appreciated.
  • 2 more comments
  • nstudio_pl Jun 01, 2010
    It's a DESIGNJET z6100.
    Thanks, but unfortunately, it's not a solution. As i mentioned the problem is caused by pinch rollers - they leave track on the media. The track is wave-shaped, same as pinch rollers "tread".
    I asked about designjet.
    It's vertical,not horizontal.
  • HP Master
  • 4,924 Answers
The lines are caused from stray ink on the rollers and on the developer..to get rid of them you have to open it and clean the developer ..the rollers and all that get in contact with the paper..The ink itself do not cause this ..but some foreign corps attached on the parts that get in contact with the paper and on which the static electricity cause the toner to adhere and than get on the paper..so ..opening and clean them it is teh only way to get rid of them ..
Posted on Jun 02, 2010
  • 313 Answers
Calibrate paper advance. you are going to need to increase the percentage to get rid of the dark banding..
Posted on Jun 01, 2010
  • Randy Trent
    Randy Trent Jun 02, 2010
    Sorry more of your previous posts poped up as I sent that last one. I have a good trick for you for the Track issue. I had the same issue one of mine.
    1. I cleaned the rollers with isopropyl alcohol. After 30min of if they are clean, then your printing space might be too humid or too
      warm. keep in mind you are using aqueous media. that media is coated
      with a thin layer of synthetic gelatin.
      if that coating is softened in any way it will allow the pinch rollers
      to emboss themselves into the media. also, pinch rollers can alter the
      charge at contact causing the ink to behave differently along those
      tracks.
      i've got a lot of experience with pinch roller tracks because i print on
      veneer and aluminum, etc. NEVER do i use a stock substrate. so I've
      seen this in a lot of situations while trying to develop my coatings and
      such.
      bath i
      cleaned them with microfibre cloth. Then waited a day so the residues
      evaporate.
    2. You can use any mild cleaner, but it will take more applications to get it all off.
    I have no idea where you are in the country or out of it, but if the tracks are clean, then your printing space might be too humid or too
    tracks.
    I've got a lot of experience with pinch roller tracks because i print on
    such.
    Give this a try and let me know how this works for you.
    Thank you for the chance to help.
    Randy
    FixYa Support Team
    Novelist:
  • 116 Answers
Typically, vertical lines appear in the copy if the glass plate is not clean enough. Clean the glass plate using a soft cotton tissue.
As the paper is moved over, small fragments of the original media or dust stuck onto the glass plate may cause image quality problems, like undesired vertical streaks appearing on the copy. To minimize this problem make sure that your original is completely dry before loading it into the scanner. Take care to protect the scanner from dust.
I hope this helps!
  • HP Master
  • 6,993 Answers
follow the below step as it should solve the problem:
  1. Make sure that the paper type you have loaded corresponds to the paper type that you select on the front panel and in your software.
  2. Make sure that you are using appropriate print-quality settings for your purposes. In some cases, you can overcome a print-quality problem merely by selecting a higher print-quality level. For instance, if you have set the print-quality slider to Fast , try setting it to Best . If you change the print-quality settings, reprint your job if the problem has been solved.
  3. Print the Printhead status plot.
  4. Check the paper-advance calibration status on the front panel. If the status is PENDING, you should perform paper-advance calibration.
  5. Try aligning the printheads. After alignment, reprint your job if the problem has been solved.
Good luck.
    President:
  • 1,561 Answers
Turn off equipment,open cover remove drum and toner unit.
Set aside on old newspaper and cover it with cloth so the light wont damage the drum.
Take your flashlight and look for a shield or glass about 8 inches long
usually on the surface that the cartridge rests on. Clean with swab and spirit.
If you cant find a glass or shield look towards the cieling of the inner chamber of the printer it may be there or you may find an led array which is dirty. Clean carefully.
Insert back and test to see if it will solve the problem.
Take care.
    Obviously it's a mistake as i mean designjet z6100 series.
Z6100 PRINT IMAGE TOO RED
1. Run the Diagnostic Print. Verify the health of the printheads, and replace as necessary.
2. Run a printhead alignment.
3. Run a Color Calibration on the media you will be using for final output. If your media does not support color calibration, you may need to upgrade your media to one that is supported, to be able to manage your colors, or use en external spectrophotometer.
4. Please report your results for further troubleshooting.
Apr 30, 2014 | HP DesignJet Z2100 InkJet Photo Printer
Z6100 banding verticle in black
When you banding vertical do you mean Across paper feed direction OR With paper feed direction?
If its across the feed direction the chances are thje issue remains with the individual printhead, Print out a quality maintenance print to find which Printhead is not working as well as wanted, then replace ( or clean using the plotters control panel under image maintenance.
Errors along the feed direction can be down to Software/ Main Pca /
Mar 11, 2014 | HP DesignJet Z6100 Wide Format InkJet...
Print length varies
for the best results when printing to a plotter use a digital RIP
the HP standard windows driver will attempt to fill the media to its maximum size (changing the size of print) this is most difficult to work around without the use of a rip
ensure that the driver options under paper size is set to leave at 100 %
and not to shrink or grow to fit.
that unfortunatly is all you can do without the rip
Jan 17, 2014 | HP Designjet Z6100 InkJet Printer
Hp dj z6100 banding using lexjet ink photo black only
could be the non-HP ink has clogged up the printhead. You should try a new printhead and see if that solves the problem. (I bet it returns if you keep using the lexjet ink)
Mar 05, 2013 | HP Designjet Z6100 InkJet Printer
I have a hp z6100 and it keeps saying load roller
Do you mean load up Take up Reel, in which case the Take up reel option can be switched off in the paper menu accessible from the front panel on the Z6100.
Feb 22, 2013 | HP Designjet Z6100 InkJet Printer
When tape is loaded into camcorder the tape gets chewed up - there seems to be damage to the casing
This can be due to a faulty PINCH ROLLER as it can chew if the bearing are worn out . If so this must be replaced, Also a faulty mechanism, links , alignment can make the tape to move out of the track and get chewed.
finally the tensioner of the tape which is tension band can be faulty and so it will allow the tape to be loose to get chewed down.
Jul 27, 2011 | Panasonic 5 PANASONIC MINI DV 60 DVM60...
HP Designjet z6100 printing wrong size _Example: a 400mm x 400mm print ends up coming out at 400mm x 395mm
I had the same problem maybe this will help
Problems also may occured when you rotate your file in "Printhouse"
You should make the rotation before you rip your file.
(1) "HP z6100 Banding / Print Lock Up / Length Issues"
Symptoms:
Customers using HP DesignJet z6100 with firmware version 6 and the ONYX v 7.1 HP Driver may experience banding, printer locking, and printing length issues.
Cause:
The problem is caused by the varware data written to the HP z6100 hard drive.
Workaround:
If you experience any of the issues listed above, please contact HP Tech Support. They may need to do a Disk Wipe and should only be done under the guidance of a licensed HP Technician.
(2) "I'm experiencing inconsistent print lengths. Why?"
This issue is not RIP related. Check below for workarounds with various printers.
For HPs
On your HP's printer menu, set "Extended Margins". This should resolve the inconsistent print length.
For Encads
Onyx users who have Encads have recommended the following:
* Configure the X axis in the setup menu.
* Be sure to save your settings as "User 1" (without saving the settings, they disappear when you power down the printer).
* If produced in-house, add bleed to the image.
* If produced by someone else, print the image at 101% to bump up the finished size.
* Static and slippage can cause the issue.
* Canvas media almost always shrinks about 1/4 inch per 4 feet due to moisture and weave of the media.
* Talk to Encad -- they have a worksheet that explains how to best reduce the problem.
For all others
Most major inkjet printer manufacturers say that .5" on an 86" print falls within what they deem "acceptable". If your printer has Media Feed Calibration or some other feed mechanism calibration, be sure to do it... and frequently.
Description: HP Z6100 having issues with print length. Discussed firmware versions and extended margins setting on printer
Please feel free to contact us if you have any questions regarding this solution or this case. Be sure to reference the case ID
Feb 17, 2011 | HP Designjet Z6100 InkJet Printer
I have an 8 track player that is playing the 8 tracks sped up. Also it chews some of the tape on some of them. This is two speaker stand 8 track player, One of the speakers carries the 8 track pocket. ...
Hi , it is good to hear someone in need a help for the 8 track player. I love this player, the mechanism and the sound quality due to the higher speed. Now you will need to open the set and mainly check on the pinch roller. This could be bad and to get a replacement might be difficult. so try to clean using go alcohol based solvent, clean up all the transport track area, the head and check also on the belt. make sure the tapes are not damaged as you will never get a replacement, i suggest that youmust make a copy soon. If the pinch roller bushes are worn out , it can wobble and push the tape down to chew, try to use a light emery paper to even the surface of the roller. I wish you luck and many happy hours of our old favourites. Helpful? Good day
Jun 08, 2010 | RCA Audio Players & Recorders
Light and dark banding on HP Designjet Z6100
this could be several issues. clean your encoder strip, clean the contacts on your printheads and carriage assembly. check that you are using the correct media profile. let me know if this helps.
kd
Aug 06, 2009 | HP Designjet Z6100 InkJet Printer
HP DesignJet Z2100 InkJet Photo Printer Logo
812 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
