Question about Maytag Neptune MAH5500B Front Load Washer
When you spin the drum around it makes a sloshing sound
When you spin the drum around when the machine is finished, you can hear water sloshing around. It also smells like mold/musty. Is the sloshing sound normal?
  • Anonymous Mar 27, 2014
    drum does not spin Machine will urn on but you only hear a clanking sound
  • Maytag Master
  • 3,740 Answers
Your unit is not draining correctly. The mold and musty smell you notice is a result of that water becomning stagnant that that is not being pumped out.
The repair manual 16010061.pdf states to check the drain for restrictions. After that if there are no restrictions you check the pump motor for 18 Ohms across the winding terminals. The final step is to change the pump.
Here are the steps for cleaning the pump:
CLEANING THE PUMP
The pump assembly can also be disassembled without removing the hoses from the pump
(See Figure 6-6). Not included in post
1. Depress the locking tab on the face of the pump housing. Top Rh front of rectangular box on pump body side.
2. Rotate the block portion of the pump containing the motor windings toward the front of the washer. This will disengage the locking tabs of the pump housing from the pump face.
3. Carefully remove the pump body away from the housing. The drain impeller is exposed for cleaning.
Thanks for using FixYa.
Kelly
Posted on Jun 01, 2010
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
Kenmore 2600 TOP LOADER smells like Mildew. I can hear water sloshing around under drum. Is that Normal?
The drain on all washers have this issue. Unless the drain hose runs down hill, when the pump stops, water runs back into the machine that was in the hose but was not drained.
Feb 17, 2014 | Kenmore Washing Machines
Kenmore Elite oasis 2709 ol signal came up, initially sears repairman said that the drum needed to be replaced so they ordered one and about a week later it showed up, then I wait a week for service guy to...
The "liquid" you here sloshing around in there is supposed to be there,it helps it to stay balanced when it spins at Hightower speed. Also you should use the "clean washer" cycle about once a month,... It helps get rid of the hard water deposits that build up, unless you have a water softener unstaaled in the house - but most people don't. If you do a lot of laundry, the strut rods that hold the drum in place wear out( mine lasted six years) and that will make it out of balance when it goes into drain and spin cycle.
Oct 24, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
When I hand turn the drum I still hear water behind the drum please help
You most likely are not hearing water remaining in the tub. You are hearing the water slosh around in the balance ring that is attached to the spin basket. There is a balance ring attached to the spin basket that is half filled with water. When the basket is turned by hand you will hear the water in the balance ring. This is normal.
Mar 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
My washer fills up, but not inside the machine. If I put the machine on spin, the water drains out. Why won't it fill inside the machine?
The water is going into the machine, but somewhere below the inside drum. I can hear it sloshing around if I move the inside drum. If I put it on the spin cycle, it does not spin, but the water comes out of the hose and into the sink.
Nov 09, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Water remains in tub after spin cycle
Have you tried to clean the drain hose on the back of the washer? It may have build up inside that you are loosening up by using bleach.
Sep 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Draining neptune washer
The sloshing sounds you hear are supposed to be there. Actually, it was there when you first purchased the washer and had never used it before. It's part of the balance system. When the machine goes into high speed spin, the balance system kicks in. The water portion of it is forced outward by centrifugal force. Now when the machine slows down and stops, the water settles back down so that when you reach in and turn the drum by hand, you can hear it sloshing about.
Hope this helps,
SG
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Mother's Maytag Neptune front load washer has water left under the drum after the final spin cycle. I am not sure that this is normal. Please advise.
This is normal to hear water sloshing under the drum when machine is done washing and you spin the drum. This is part of their water balance method to help spinning procedure. I called a Maytag repair shop and they helped with my question.
Jul 23, 2008 | Maytag MAH6500 Neptune Front Loading...
Water in Outer Tub
My washer does this too and I called Maytag and was told it was normal. I don't like that answer, though.
Mar 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
522 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
