Question about LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer
How to replace the washer/dryer drain hose
My LG WD1435RD has a small split in the corrugated drain hose. I have the replacement part and have just unscrewed and removed the back panel of the washer/dryer. I can't properly reach/see the end of the hose where it attaches near the front of the washer. Is there another way to access this connection except from the back? Any other suggestions?
dutchman05
  • 487 Answers
SOURCE: How do I connect the
the drain hose needs to be attached appr. 32 inches above the floor and needs to have an airgap between the drain pie and the drain hose in order not to sifon the water out of the machine.
What you can do with the duratub is:
Hole in the side where the washer is. Get a drain pipe for your duratub with a side connector for dishwasher and/ or washer. make sure that the Ptrap is at least 5 inches below the connection point in order not to have the sifon effect
Posted on Jun 15, 2008
onthejob5130
  • 640 Answers
SOURCE: LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head screws...now the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
Posted on Dec 25, 2008
  • 105 Answers
SOURCE: LG WM2487 front load washer spews suds out of port on rear.
You are likely using too much detergent or the detergent is not high-efficiency detergent. Change detergents and/or lower amount and this problem should go away.
The water port on the back allows air inside the tub to escape. However, if the wrong type or quantity of detergent are used, excess suds will flow from this port.
Posted on Aug 02, 2009
SOURCE: LG WM2010CW filter drain no draining
In all likelihood the rubber drain hose is clogged. I had the same problem with my LG front loader. The hose was clogged with sand and dirt almost the entire length of the hose. The following solution is far simpler than taking the dryer apart to clear the drain hose. Besides I figure this same thing could keep reoccurring with all the sand and dirt we get in our clothes here in East Texas.
I purchased about 4 feet of 3/16 inch OD vinyl tubing and adapted it to fit on the end of a garden hose. The adapter gizmo included a valve so I could control the water flow and not give myself a bath. A picture of the gizmo is included below. Make sure that when you connect the water hose to the faucet that the faucet valve is just slightly opened and that the gizmo valve is closed. Using the gizmo is straight forward. First remove the drain filter and than insert the vinyl tubing in the end of the rubber drain hose and slowly open the valve on the gizmo. Make sure you have a large pan or bucket underneath the drain hose to catch the debris and water. Slowly advance the tubing up inside the hose until it won’t go any further. By this time water will also be running out of the drain filter cavity which will indicate the clog has been removed. Continue back flushing for a few more seconds to assure all the debris has been cleared, than clean up and you’re finished.
Posted on Mar 16, 2010
SOURCE: I neet o replace drain pump on a LG wm1832cw model
its not easy, but you'll have to lay the washer on its back and take off the crate like bottom panel. Discontect all the hoses. Disconnect the electrical line going to the pump. If you can, try and seperate the pump motor from the housing by unscrewing two screws on the housing, which will seperate the motor from the housing, If you cant get to it, I actually broke the screws on the drain filter housing to get it loose. I secured it back with the other front loading screw and some gorilla glue, shouldnt be a problem. I should at least get another 6 years out of this pump. Good luck.
Posted on Jul 10, 2010
My lg front load washer posted this ER: check the drain and the hose. we checked all the drain. but the machine stopped when it was on SPINNING. the ER POSTING : CHECK THE DRAIN is back
Water comes out of the drum through a soft corrugated hose, into the filter, out of the filter through another soft corrugated hose into the pump and out of it through the hose that is put to the drain. Have you checked all of these pipes? Sometimes something small can get past the filter and get stuck in the pump. If it is all clear, then perhaps the pump is faulty.
Aug 03, 2015 | LG Washing Machines
My lg washer and dryer wm3431hs isn't draining. I took of the hoses in the back, cleaned the filters and still nothing please help!
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...
Daniel
Jan 10, 2011 | LG WM3431H Washer and Dryer
My drain hose split and I don't know how to open machine to change it I add a pipe and 2 brackettes but its leaking so I need a new hose
There are 2 screws at the rear just under the lid, remove them and the lid will slide back a small amount and lift off.
Apr 18, 2010 | LG WM3431 Front Load Washer / Dryer
Need 90" Drain Hose for GLET1041AS1 Stacked Washer/Dryer. Part Number on Hose is: 1314612 OEM 3
The part number of your original drain hose is 134049200. There is an 8 ft corrugated drain hose with a part number SSD8 and has a universal end which you can cut to fit, and is approximately 96 inches long. hope this helps.
Thanks
Oct 11, 2009 | Frigidaire GLET1031 Top Load Stacked...
Kenmore front loader not draining or doing a "real" spin cycle
Hi...
There are several ways to fix this problem, we need to check first the parts before we do a hard troubleshooting. Check this parts first.
Inspect the drain hose for kinks
Test the timer control
Test the lid switch(some models)
Inspect the water pump
Inspect the driver belt(belt drive only)
Inspect the motor coupler
Those are the parts that we need to check
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Good luck !
ICmanServer
Aug 01, 2009 | Kenmore 22422 Top Load Washer
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
LE error, won't spin, I've replaced the sensor
check out the DRAIN MOTOR PUMP ,it could be clogged with lint & debris , just follow the drain hose where it ends connected to a small motor , take it out and clean it , hope this helps AJ
May 17, 2009 | LG WD-3632HW Front Load All-in-One Washer...
Water fills drum (top loader) even when off
Your problem is a jammed water solenoid, If you take the top off the machine it is possible to remove and either strip it down to see if it is dirty or replace it. your washer hose usually connects directly to it.
Apr 11, 2009 | LG Washing Machines
Aug 18, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer Logo
216 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
