Panasonic home cinema model SAHE 70,every time i turn it on all i see is OVERLOAD with or without the speaker's connected to it
  • 1,512 Answers
Hi robertdesj
I am afraid to tell you mate that the News isnt good. Your amp has an internal problem operating the protection circuit. It may have a failed channel, or maybe a blown fuse... work checking for... be sure to disconnect from the wall before you do anything !!!
If none of the above, I am happy to yak to you more about the problem.
If you think this is good advice, HITME with a "FixYa" rating.
Posted on Apr 09, 2008
Hi I've got a Panasonic sc bt100 home cinema could someone tell me how to get the surrounds to work without having wireless speakers I've noticed inputs on the back of the system but it doesn't work ?
Not quite understanding what your problem. The surrounds simply connect to the rear connections of the amp. The rears will only play when the source material has surround info.
Sep 02, 2016 | Panasonic Audio Players & Recorders
I have buyed a panasonic 5.1 home theater before five years due to electrical variation the player was damaged all the speakers are in good condition ineed a suitable player to run the home theater need...
If your Speakers are in good condition, you can try buying a suitable wattage AV receiver with a bluray player of your choice brand ( Yamaha, Onkyo, Harmnkardon, Denon, Sherwood...etc) You can utilise your favorite speakers again.
Oct 27, 2013 | Panasonic 5.1 DVD Home Cinema System 1000W...
I have problem with my home cinema Panasonic home cinema SA-HT 870. I can't turn on. when i push the buton on/off i hear zzzzzzzzzzzzzzzzzzzzzz and i see on display EROR F61 and after 3 sec system is turn...
this error comes when you keep your device powered all the time.
Definition: power is constant to components always on so it heats up.
look for condensers that are popped up or seems to be
change it with same type and voltage
Description of Error Code. F61
State, Condition
When the power is turned on, the unit is automatically
turned off. The power does not turn on.
· Cause, Troubleshooting
Power circuit system failure and/or direct current flown to
speaker terminal
Good Luck
Nov 19, 2017 | Panasonic SC-HT740 System
Replacing Panasonic SA-HT500 with Newer Model that has HDMI Input
ANY amp will be ok, as long as the wattage of your new amp does not exceed the wattage of your speakers. Otherwise you could overdrive your speakers and damage them. First clue, if you turn up the volume and the speakers start to shut off and on you are pushing too much power to them.
Feb 03, 2010 | Panasonic SC-HT500 System
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Dec 12, 2009 | Panasonic Home Theater System System
Panasonic sc-pt460 home cinema system not getting
1 of your ics could be blown causing the amp shut down
Jul 15, 2009 | Audio Players & Recorders
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
Having just bought a Panasonic TX-37LZD80 television and a panasonic sc-pt460EB-K home cinema system, I connected the 2 together using a HDMI Cable and all works well except that I cannot get the sound...
When I purchased the television iI was told that I would only need a HDMI cable to connect the devices together, this is not true as the HDMI only provides 1 way transmission, to get the sound to go from the television back to the home cinema you need to use either a Phono Lead or Optical lead, plug them in and Hey Presto it works.
Jun 23, 2008 | Panasonic Televison & Video
101 people viewed this question
