Question about Sony Playstation 3 (PS3) Console
Lines running up screen of my tv when i turn on my ps3
  • Sony Master
  • 17,970 Answers
It's not a problem with your PS3. Rather it is the component cable. When you had a component cable, you used to have a faint line running up the screen. You switched to HDMI, and the problem was solved.
If you can't get HDMI, then you are stuck with what you have. It could also be interference from something else, some other cable (analogue interference. HDMI is digital and does not suffer from the same problem)
Also, try to unplug the cable TV line from your TV and see if the problem goes away; then disconnect the cable tv from the back, and then it should work fine. It's possible you have a "ground loop" because cable tv (the coaxial cable) is a path to ground, and the PS3 has a path to ground. To fix it you'd need to buy a surge protector that lets you plug your coaxial cable and your PS3 into it.
Hope helps.
Posted on Jun 01, 2010
When I switch my tv to the HDMI input it appears to be normal for a few seconds but the screen stays black and I get a thin pink line running horizontally across the bottom right corner of the screen then...
You did not mention what you are connecting with HDMI but I have had problems with my PS3 and it is copy protection related. On a PS3, you have to connect it to HDMI1 otherwise some BlurRay movies will not play.
You might have a bad HDMI cable. I have heard the quality of cable does not matter these days but I still have had issues with the really cheap cables. I still do not buy the really expensive HDMI cables though.
Aug 29, 2011 | Zenith Z50PX2D 50 in. Plasma HDTV
I have a PS3 slim that often have video problems. When I use the AV cables, it shows white line, and if HDMI, blank screen. The console does not turn off, no blinking lights. When I turn off the console,...
Does your tv run everything else fine? Sometimes cables r screwy or the tv is screwy(I'm not denying that you have a bad ps3) but you can still get the warranty on it. If the second one does it,it's not the PS3 its your tv or your cables.
Oct 27, 2009 | Sony Playstation 3 (PS3) Console
Screen has lines vertical and spaced evenly reset still there. looks like bad video card. system works just lines all the way throw it. its all the time, games movies, home screen. did a reset, same thing,...
Do you have any other HD devices to cross-check with? If it's occuring with all HD devices then it could be the TV itself having trouble. It could also be the HDMI cable; do you have an extras you can try?
Have you attempted to reconfigure the PS3's video settings? Try a number of different combinations and see if any of them result in a cleaner screen. Hopefully it is the connections and neither the PS3 or the TV. Also, find your TV's make and model and attempt a search to see if any one else is having issues with that particular TV.
Jul 08, 2009 | Sony Playstation 3 (PS3) Console
INSIGNIA TV FLAT PANEL (not LCD) cant play PS3
Check to make sure it is on either the AV 1 or AV 2 channel
Nov 25, 2008 | Televison & Video
Thin line of colour run across tv screen
Got my mate to look at it ! He had to reset the factory settings for the HDMI (my son was'nt to chuffed as he lost all his saved stuff ) also the screen setting were set to a lower sieze? what ever that means ? but its solved the problem
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
Ps3 sound problems
check your cables connecting your ps3 to your tv. there might be ground somewhere.
hope this helps.
Jan 28, 2008 | Sony Playstation 3 (PS3) Console
Green Line
It may be a video setting in the PS3 is not matching the TV. Try this. Turn off your PS3. Then, press the 1/0 button for more than 5 seconds. This should reset your video settings.
Nov 06, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
