Question about Vulcan SG4D Gas Single Oven
Oven doesn't turn on. pluged in indicator lights on, slight smell of gas present. seems that it's not igniting
  • Vulcan Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Jun 01, 2010
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Kitchenaid superba oven
check the igniter for oven and change
you may have a seperate igniter for the broiler
Nov 15, 2013 | Ovens
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
When i set my oven to turn on, it doesn't heat up. Sometimes I get an oder of gas.
Good evening
First ,a couple of questions.Is this an electronic ignition? Most likely yes,as this problem seems to happen with E ignitions. Open broiler door,turn on oven and look inside .You should observe an orange glow appear .(Small blue flame indicates standing pilot) If yes then wait for ignition.No or partial ignition or some gas release means you need a new igniter.Very common. They do get weak. Inexpensive fix.Couple of bolts and plug.
PLEASE TURN OFF POWER TO MACHINE BEFORE SERVICE 120 volts down there.
good luck
Was this helpful?
Aug 18, 2011 | KitchenAid Ovens
When turn oven on can see the igniter coming on.but it doesn't light.can smell the gas
You need to replace your igniter. Very common replacement part.Igniters can look ok but can be failing and not drawing enough amps to open gas valve . Disconnect power before attempting.
hope this helps
Aug 15, 2011 | Whirlpool Ovens
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
Hoping someone can point me in the right direction. Oven won't light, but the stove top burners are fine. Don't smell any gas or any indication the oven is attempting to light....
next time send the brand name and model number so i can look up your machine,if it's a gas stove most likely it will be a bad ignitor,even if the ignitor glows it still could be bad,if the flame doesn't ignite and the ignitor is glowing change it out,if it isn't glowing pull out the ignitor and check it with a meter,common problem.
May 07, 2011 | Ovens
I have a hotpoint RGB745EEHBB, and after i turn the oven on to cook I can see the coil glowing but I smell gas, and then after about a minute or so I hear a boom and then finally its lit, what can be the...
You need to replace the igniter, it controls the how much the gas valve opens by how much electricity passes through it. Sometimes when the igniter gets weak, it opens the gas valve just slightly but it is not yet hot enough to light the gas. you can purchase the igniter you need at http://www.reliableparts.com/ using your model number.
Nov 30, 2010 | Hotpoint Ovens
Oven is slow ot light and has a gas smell when
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 21, 2010 | Kenmore Ovens
Kenmore Gas Range
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition
Jul 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Vulcan SG4D Gas Single Oven Logo
137 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
