Question about DiMarzio Dp215 Evo 2 Bridge Pickup Regular
I have a guitar im trying to install new pickups on but they set down inside and mount directly to the wood underneith and i cant keep the springs from falling off this does not use a mounting ring or a pickguaud this is a tough one
    President:
  • 1,137 Answers
Try holding the pickup in the cavity in the position you want without the springs. Use a bit smaller than the mounting holes in the pickup to predrill the holes in the body through the pickup holes while you are holding the pickup in place. When you are ready to mount the pickup use a little hot glue on the ends of the springs to hold then in place over the mounting screws on the bottom side of the pickup. With the screws and springs in place on the pickup carefully screw the mounting screws into the predrilled holes in the cavity. Try using a pin vice to hold the drill bit or one of those small drills that you can operate with one hand( your second finger and thumb hold the slider and your index finger does the downward stroke). Here is a link to a really good site:http://www.stewmac.com/freeinfo.html
Posted on Jun 03, 2010
How do i install the flexable pickup in the bridge groove?
You didn't say what make and model of the guitar or the pickup, so this is just a generic answer.
Remove the strings and saddle. center the picup in the bridge slot noting where the wire is located and mark where it needs to exit. drill a hole just large enough for the wire to pass through. Check where you want to install the output jack. If in the side, drill a mounting hole. If you're using an endpin jack, drill the appropriate pass through hole..
place the pickup in the slot pushing the wire though the hole, then out though the ezit hole. press the pick up in place with a q-tip, toothpick or some other nonmetalic probe. re-install the saddle and string the guitar. temporary solder an output jack to the wire and try it out before permenently installing the out put jack as you may need to reposition the pickup right to left in the slot to get the strings balanced. once it sounds right, install the output jack
Feb 12, 2016 | Music
How do i wiring an active pickup and a passive pickup in same guitar
Not hard - just wire up one pickup and leave the other one alone. The active pickup will have wires that say "output + and - " - just use those to connect to the same place you would attach a passive pickup. Also, an active pickup will need space for a battery (9v). I weould consult EMG pickup installation for diagrams. You will also probably need to replace the guitar jack with a TRS, where the ring is a "killswitch" for the battery when the guitar is disconnected.
Try this diagram set: http://www.emgpickups.com/skin/frontend/emg-2013/default/pdfs/2-tw-2v-1t-only.pdf
Feb 14, 2015 | Music
The pickup on my epiphone pr5 booms if i play loud, and if i tap the body anywhere it scratches and booms even with new battery
Sounds like you are using incorrect settings on the amp you are using. Try all tone controls at 12 o'clock as a start. Excess bass boost is a good way to have the problem occur. Also back off the volume control. "Handling" noise or scratching from handling the guitar is NORMAL for this type pickup. Back down the volume and DO NOT boost the highs or lows to help with the handling noise problem.
May 23, 2011 | Epiphone PR5-E Electro Acoustic Guitar...
Hi ive had a fishman pick up installed under saddle of my accoustic guitar its fine but something is wrong becuase wen im slapping the strings and tapping guitar the sound goes very quiet for around 1...
It is possiblle that the sudden pulse from the pickup due to tapping is saturating the input of your amplifier, and that is what actually kills the signal. Try this into a different amp as a test. Once you do the test I can offer some suggestions to try.
Apr 23, 2011 | Fishman PRO AG-094 Under Saddle Acoustic...
My s5470 does not sustain well at all.also,the bridge pickup sounds ok but lacks ''attack'' in upper register.great guitar otherwise.i use a peavy 5150 60watt amp.
I personally use Seymour Duncan Humbucker pickups, and have never been disappointed. You might want to take your guitar up to a music shop and try it on different amps to see if your amp is your problem, or if it is your guitar's pickups or wiring. You could also try adjusting the height of the pickups until the sound you are looking for is achieved. I have also had guitar cables make a big difference in the sound. Make sure you have a good set of cables, and you may want to adjust the EQ settings of your amp to make up what the guitar lacks.
Apr 15, 2011 | Ibanez S5470 Prestige Electric Guitar
Hi, After installation of my fsk-401, it worked fine, but after i fine tuned my pickup heights to the specifications on the installation manual, it started screeching everytime i flicked it on. Also, it...
Understand that in a feedback system if the gain exceeds plus one, it will oscillate. This sustainer kit PROBABLY pushes the gain up close to this feedback point and that is the way it works when set correctely. This is called regeneration. This is technical stuff...
The pickup heights are likely the main control of this feedback gain, so raising the strings up relative would be in the right direction.
ALSO IF your guitar can "hear" your amp, then you can have feedback due to the sound vibrating the strings. Try turning down the treble on the amp and see if that might help.
Some electronics when run with dying batteries becomes unstable.
These are just suggestions based on my engineering experience. I wish I was there to run some tests as that is the way to troubleshoot.
Mar 02, 2011 | Fernandes Sustainer Kit by
Im replacing the pickups and i want to know what wires go where? theres like two wires connected right now but the new pickup has four.....schematic?
The company from where you got the pickups would have the schematic. What pickup are they.
When there are 4 wires it usually to split the coils in the individual pickups
Dec 14, 2010 | Epiphone Les Paul 100 Electric Guitar
Diagram to install pickup in electric guitar
Try here:http://www.blueguitar.org/new/schem/_gtr/ or here:http://www.guitarelectronics.com/category/wiringresources/ or if you know what brand and model pickup try Googling their website. There are usually diagrams at each site under support.
Jun 16, 2010 | DiMarzio Dp181 Fast Track 1 Stratocaster...
Need help putting my guitar together
The "handle type thing" is a Tremolo or, more often referred to as a "whammy" bar. The thing at the base of the strings is called a bridge. Looking at the strings, there should be a hole to the right of the smallest string. If your "handle" is threaded, stick the threaded end into the hole and rotate in a clockwise motion. Once is hits the bottom of the threads, back it off one turn and gravity will let it hang out of the way while you play. If there are no threads, it will slip in and you will feel a "click" when it's in the proper position.
On the back of the guitar, there is a cover plate that covers the cavity where the springs are located that make the "whammy bar" work. The springs hold tension on the bridge so you can tune it and play normally, but let the "whammy bar" stretch or release tension on the strings when you push or pull it. If you already have springs inside the cavity, the extra spring you have will let you add more tension to the bridge, but you probably won't need it. If there are no springs already installed, you can install your "extra" spring in there to give you the flex and spring for the "bar-handle" to work properly.
To install a spring, loosen or remove your guitar strings, open the cover on the back, and install the spring over the hooks on the bridge and the hook on a metal bar on the other end of the cavity. Replace the cover, insert your "handle", and wiggle-away.
The allen wrenches are most likely for adjustment of the moveable pieces that support the strings on the bridge. The bridge has adjustments for up and down, and forward and back to adjust the height and distance where the string is supported. Don't adjust the bridge supports unless you loosen the strings. It is highly recommended that you don't make any adjustments yourself unless you are familiar with the mechanism. You can adjust your guitar where it's impossible to keep in tune if the adjustments are not perfect. There are usually guitar repair shops close by and offer "set-up" services to get your instrument adjusted properly. It's well worth the money to have it done right, and the service people with often teach you many things that will help keep your instrument playing well.
Hope this helps.
Jim
jimmydsmith@cox.net
Phoenix, Az
Jan 10, 2009 | Fender Squier Std Strat Mn Car
DiMarzio Dp215 Evo 2 Bridge Pickup Regular Logo
80 people viewed this question
Top DiMarzio Music Experts
Vito Vacirca Jr.
Are you a DiMarzio Music Expert? Answer questions, earn points and help others
