Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Gemini Dual Oven MER6772BCA
Our Maytag Gemini MER6772 seems to have burned out the upper right coil in the upper oven. The upper oven would not turn off and the control panel was extremely hot. I had to throw the breaker switch to turn off the range.
Any suggestions as to what might be going on?
  • 1 more comment
  • SFC2591 Apr 09, 2008
    Thanks, I will check it out. Where would you recommend the part be purchased from?
  • SFC2591 Apr 10, 2008
    Can you tell me if this is something I can do myself or is a tech required? Any hidden issues?
  • SFC2591 Apr 15, 2008
    I replaced the element in the upper oven MER6772 BAC and it seems to be working although the temperature does not seem to be as before. In addition, one of the rear cooktop elements is not coming on. Can anyone please advise as to what might be going on or if this is coincidental?
    President:
  • Maytag Master
  • 2,651 Answers
Sounds like the broil elemnt in the upper oven is shorting itself out part number 74004106, probly 45 bucks. leave the circuit off adn replace it... the wire(s) leading to it are always live.theres a few screws across the top of the cavity holding it up
Posted on Apr 09, 2008
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
Power went out, now ovens are 'locked' - how to unlock?
I DO know the lower oven door can be released by lifting gently up and to the right, and a little 'joggling' will allow the door to be opened. It seems the lock latch swings to the (almost) locked position unpredictably and intermittently. I hate this @#$% stove. So does my wife.
The upper oven door has never seized. Upper oven has burned through several elements, and it's dangerous to replace. NEVER TRY ANYTHING WHEN CIRCUITS ARE STILL LIVE.
I hate thjis stove. I REALLY DO HATE IT.
Nov 08, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Gemini Electric Range MER6772BAS- lower oven upper heating coil doesn't work. Everything else works fine.
Replace upper coil by removing,and take it to applance parts dept and have them order a new coil(check coil by using a test meter look for low ohms.
Jul 17, 2010 | Maytag MER6772 Gemini Electric Kitchen...
F1-1
Your Maytag Gemini is giving you the fault code for either that's it's lonely or for a "Runaway Cook Upper Oven". Now that I look at the choices the one I made up doesn't seem so funny.
Yes you have a runaway upper oven. The repair manual says to check the oven temperature sensor and replace if necessary.
Your temperature sensor will look similar to the ones in the image below.
Chances are you need a new one. If your handy with tools, replacing it is pretty straight forward.
Try the link I included for parts. They are as cheap as anyone else.
Hope this helps.
http://www.partselect.com
Dec 21, 2009 | Maytag MER6772 Gemini Electric Kitchen...
I have a Maytag Gemini, top oven burns everything on the bottom
RAISE OVEN RACK SHELF, BOTTOM ELEMENT MAY NOT BE TURNING OFF, NEEDS REPLACEMENT
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
MER6772BAC Dual Range Oven
sure sounds coincidental, most of the time its a faulty infinite the elements rarely go bad, i guess you can pop the top up first and look fro a burnt wire
Apr 14, 2008 | Maytag MER6772 Gemini Electric Kitchen...
MER6770 Fault Code
No. just the one sensor part number 12001656. After paying a maytag repairman twice, I will now for the third time replace it myself, google the part number and you will see the different companies that sell it. Price runs up to 40.00, next time buy a different product and hope that Maytag goes out of business!!!! I know I will!!!
Dec 17, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
345 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
