Question about Clarion DB285USB Car CD/ MP3 Player
Hi...I have a Clarion DB285USB car stereo....the unit played perfectly, but after being locked out of my car and having a car service technician break into my car....the alarm sounded and the technician disconnected the car battery...then he turned the alarm off with my key....now the radio won't turn on. Can you help me?
  • 239 Answers
Check your fuses in your fuse box and also the fuse in the back of the radio
Posted on Aug 19, 2010
Clarion PE 2528KA code required MR925632
Is there any papers for the stereo? is there a way to obtain this code from seller?
Feb 04, 2012 | Clarion Car Audio & Video
Does this unit have RCA line out jacks......
According to the specifications on the Clarion website it has:
  • 4ch/2V RCA Output (Front/Sub)
    So in answer to your question I believe it does have RCA line out.
Mar 07, 2011 | Clarion DB285USB Car CD/ MP3 Player
I changed the battery on my truck and the stereo went into enter password and dont know what it is and now it is locked
Assuming you have tried standard default codes 0000, 1111, 1234...
Clarion models keep the security code in non-magnetic memory inside the unit.
The only way to reset is to return it to clarion to have it cracked and reset using their proprietay software, and/or replace the flash memory chip.
Clarion authorized service centers cannot even do it (like Kenwood can)
If it says CODE, you can attempt to enter a code. If it says LOCK - after 7 attempts, you must wait 15 minutes.
Hope this helps
Regards
Dan
Jan 02, 2011 | Car Audio & Video
Unit will not eject CD will play fine but won't eject
Once it gets too hot in your car, a stereo or the cd in it can warp.If you press the eject button and the music keeps playing the unit has an electrical problem you can't fix. If you press eject and the disc sounds, or looks like it wants to come out, you might have a warped disc. As a last resort, pull out the stereo and leave it connected. Then try to eject it. If it ejects, then the stereo could be binding.
Apr 12, 2010 | Clarion XMD3
My clarion CD player in my Nissan Primera P12 2004 will not eject the discs can this be rectified and would it be expensive.
Hi.
Check first that it is not a single disk stuck inside.
Try pressing repeatedly the eject button on the on dash player while at the same time you start the stereo.
If that does not work you can try disconnecting the car battery to reset the unit, and then attempt again the procedure above.
Remember that you may be asked stereo code after disconnecting battery, have it ready.
If still no luck, then the unit must be removed from the dash to be taken apart, so to remove the stuck disk.
In that case the repair may require replacement of CD drive unit or front panel. When disk does not exject repair done from a local technician may be expensive. Usually better replacing the whole stereo unit.
Regards.
PS: Here the procedure above illustrated in detail. The procedure is described for home DVD players, but it is the same on any optical unit, including in-dash stereo. Naturally , since the unit is an in-car system, you do not have power cord, but you will need to disconnect battery to reset the system: player system won't eject disk.
Mar 16, 2010 | Clarion Car Audio & Video
Clarion boat stereo- Error 6
well over time the cd reader in side the unit goes and that what is happen to your unit best solution replace the init
Jul 01, 2009 | Clarion DXZ545MP CD Player
Peugeot 206 53 reg stereo compatability
I don't think it's that easy to find unless the stereo clearly specifies it..I have the same problem too and have given up..
Jun 17, 2009 | Car Audio & Video
Clarion DB285USB Car CD/ MP3 Player Logo
246 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
