Question about GE Refrigerators
Refrig ice maker inlet freezing
I have a 3 year old GE Side by Side GSS25QGTA Refrigerator. The water inlet line to the ice maker has started freezing as it enters the back of the fridge. Water then begins to run out the water input area at the top (back) of the fridge. I cleared the ice block but the problem returned within 12 hours.
  • 7 more comments
  • Anonymous Mar 11, 2014
    I have a glass top range that the range works fine, but when i try and turn on the oven and push the arrow buttons to get to the temp i want it will not come on and the pad says PSH or P5H not sure which it is.
    Need to check a couple of the ignitors on it two are clicking and one does not try to light
    How to bypass the parking brake to play videos on the pyle pld10bt
    Whirlpool 8575637 rinse aid not dispensing
    Panasonic 1200 watt High Power NN-ST6715 has been working just fine; displays correct time after resetting for daylight savings time; now when I set time to microwave and press start the time display goes dark and then resets to clock time - with no micro wave action! any suggestions - Franklin in Frozen Alberta
    farm is locked because of security issues, therefore I cannot access my farm cash of $1900.00 which I purchased on Feb 26 for 189.89
    red light lit. message "outer temp. open cycle power
    Brand new WDT710PAYM Whirlpool Gold DW. Carefully installed. Ran 2 test cycles (no dishes) after install. Water on floor at front below door. No leaks from drain or water inlet hoses. Appear to be door leaks. Door securly latched. What is problem?
    changing fuel filter in 1998 GMC sierra
  • 776 Answers
Have you checked for any water leakage around the water inlet.
It looks like that the the water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube.
Please disconnect the ice maker line from the valve and watch to see if it has a slow drip, as it can easily block the the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Awaiting reply
Posted on Jun 07, 2010
GE ice maker
If the freezer is cold enough to freeze food hard, look for a problem in the water line, water inlet solenoid valve, or possible ice build up on the ice maker itself that does not the allow the ice maker to complete it eject cycle and start a new ice making cycle.
Jul 14, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
I do not believe the other advisor understand my problem. I have a GE Profile Arctica refrigerator PSS25NGMDBB. The problem is the cup fill (GE part name) is frozen and full of ice. So when the ice...
You are right. The water inlet valve is leaking a small drip and it freezes when it reaches the cold air in the freezer at the fill tube. Melt the ice in the tube with a hairdryer and replace the water inlet valve. It's on the back where the water supply connects to the back.
Feb 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side refrigerator about 7 years old it has a thru the door ice/water dispenser the water seems to be dropping in the ice tray inside the freezer and freezing in a mass at the bottom of...
Your inlet valve is malfunctioning. Sometimes when they go bad they either let in to much water or none at all. It is located on the back under accesss panel where your water line connects to your fridge. Rate me if I helped you!
Aug 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
No ice.
Pout about 2/3 cup of water into the ice maker . If it dumps but does not refill , replace the water inlet valve ( the piece the wall water line connects to behind the refrig ) . Also check the tube which fills the ice maker as it will freeze up , not letting water go into the ice maker . This is also caused by a bad water valve .
If the ice maker does not dump the water poured into it , replace the ice maker .
Also , check that the coils are clean under the front of the refrig , as this will cause slow ice production and can cause the ice maker not to dump due to too warm of temperature . Ice maker has to be 5 degrees to operate .
May 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My GE side by side ice maker quit making ice, no water sees to be entering the unit.what do i check for?
Pour 2 / 3 cup of water into the ice maker .
If it dumps the cubes , but does not refill with water , replace the dual water valve behind the refrig . This is the piece , the wall water line connects to , on the refrig .
If it does not dump the cubes , replace the ice maker .
Oct 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Me GE Profile PSC23M Side by side ice maker quit making ice and water was on floor behind refrig. Is a water line frozen or clogged or do I have to replace ice maker?
It sounds like you just have a leak at the back. Try swapping the wires on the dual water inlet valve. Then try the water dispenser and watch on the back for where the water may be leaking before it gets up to the ice maker.
Oct 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Refrigerator Ice Maker not working
Pour about 2/3 cup of water into icemaker . If it freezes and dumps the cubes , replace the water inlet valve ( piece on back of refrig that the wall water line connects to ) . If it doesn't dump the cubes , replace the icemaker . Also make sure the coils are clean under the front at the bottom of refrig , or the squirl cage behind refrig ( model number would have helped ) , of dust , lint , pet hair etc .
Sep 05, 2009 | GE Refrigerators
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Kenmore Side by Side Refrigerator Model #106.50544001
It's time to replace the dual water inlet valve (the part the water line connects to). A bit of sediment or other fine object can get in the seat or the material itself can deteriorate and allow a tiny amount of water to pass up to the icemaker.
Jan 04, 2008 | Whirlpool GR2SHWXPB 21.7 cu.ft. Top Mount...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
