Question about Yamaha 12V Air Pump
Cant start jet ski
Can't start my jet ski and i just put fully charge batery? Wer can i find fuses? YAMAHA SHO WAVE RUNER 2009
  • mddbrothersc Jun 01, 2010
    WERE CAN I FIND FUSES OR FUSE BOX ON YAMAHA SHO 2009
    Brigadier General:
  • 3,513 Answers
Thanks for contacting Fixya.com.
If you jet sky wont start,most probably it is due to faulty start button. Check for continuity. Make sure your connections are all shiny-clean, take them apart to clean. Corrosion is a big culprit in a marine enviorment.
however follow the bellow suggestions....
Attach the safety lanyard. The lanyard is designed to shut off the engine if the rider falls. It must be in place for the jet ski to start.
Use the choke. Most jet skis are equipped with a button or lever that will reduce the amount of air in the fuel during ignition. Once the engine is running smoothly, release the choke.
Give it a little throttle. Simply getting more fuel to the engine can aid ignition.
Fill the main and reserve fuel tanks with fresh gasoline. Jet skis often lack a fuel gauge, and an empty gas tank is often the problem.
Add a bottle of Drygas or some denatured alcohol to the tank. This aids gasoline combustion after a long period of storage.
Siphon the fuel tank. Water is heavier than gasoline, and will settle to the bottom of the tank. Remove all liquid from the tank and refill it with fresh gasoline.
Check the oil. If it is low, fill it up with the proper type of motor oil. Also, some jet skis may require a mixture of gasoline and oil for fuel.
Recharge the battery. A battery may lose its charge after a long period of storage. If the battery continues to fail, it needs to be replaced.
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on Jun 01, 2010
  • 1,284 Answers
Hi, you can learn how to troubleshoot your jet ski by visiting the link below......
http://www.ehow.com/how_2087096_troubleshoot-jet-ski.html
Take care
Motor runs away with its self
sounds like the carbs need stripping and the jets etc unblocking ! does the throttle link return fully to the tickover position ? or possibly the crank seals have worn letting air in !
Feb 24, 2015 | WSM 1996-1997 Yamaha Wave Venture 1100 Cc...
How do you winterize a 1993 Yamaha wave runner 2 stroke, everything we have seen says to just fog the plugs no anti freeze? is this right and if not where do you put the anti freeze in at?
NO ANTIFREEZE!!! simply hook up to the flush fitting and while running start spraying fogging oil thru intake . you want to "load" it up with that stuff and don't rev high for about 3 or 4 min the just disconnect battery and spray motor and pump down with WD-40
Oct 29, 2014 | WSM 1990-1993 Yamaha Wave Runner Iii 650cc...
Jet ski wont start
does it have spark at plugs ? carb clean and fuel new ?
Jul 22, 2014 | WSM 1997-1998 Yamaha Wave Runner 760 Cc...
What is wrong with my wave runner
Make sure you are using Yamaha oil not an off brand. It does make a difference.
Jul 17, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
Jet ski smoking
what colour smoke , correct fuel ??
Jan 04, 2014 | Yamaha Wave Raider 700 760 1100 Waveraider...
Won't start
Fuses in the electrical box?
Jul 18, 2013 | Yamaha 2006 WaveRunner FX Base
Yamaha wave runner check engine light comes one and will not run properly.
Have the fault codes read. Replace faulty items. Use only
genuine items as replacement as non-genuine are not always compatible with the OEM fitted CPU units. This results in the fault codes not cancelling out.
Jun 09, 2013 | Yamaha 2009 WaveRunner FX SHO
I have a Yamaha FX Cruiser HO (2010). The jet ski died in the water on me last week. I determined it to be a fuse. Replaced the fuse with the extra one and it burned out again. Any suggestions?
i have a 08 yamaha fx sho it keeps on freezing up in the water and dying of, i was almost 10 miles into the ocean and had to be towed by one of my fellow riders. whats causing this problem?
Jul 16, 2011 | Yamaha 12V Air Pump
I have a yam gp1200 jet ski 1998 which i bought as a non runer. I have just had the engine repaired and wondered if i will need a code to start it. I was not given any codes when i bought it....Many thanks...
Yes you will need the code to start. click on this link it should take you to the Yamaha website so you can download the owners manual. it will show you how to reprogram the GP1200 start. yamaha-motors.com
Oct 27, 2009 | Boating
Yamaha 12V Air Pump Logo
395 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
