Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My tv turns on but the screen dont work - RCA D52W20 52" Rear Projection HDTV-Ready Television
  • rhackbarth Jun 01, 2010
    my tv powers on but the screen does not work
    where do i find the power supply board?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This can happen due to many things, to start with open the back of the unit and check the power supply board for any blown capacitors. Also check the flyback as there can be some loose wires in the coil. Also inspect the convergence ICs(if you were getting a 3d/double image before the picture went out then this can be the issue) if they are working fine and please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Opening the unit is only recommended if you have some electrical expertise. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 01, 2010
  • Rylee Smith
    Rylee Smith Jun 01, 2010
    Have already advised you what can cause this, have you even open up the unit and check the things that I just told you.
  • 687 Answers
Check that you have the correct HDMI cable for you TV if its a newer model then you will need at least a v1.3 cable if this is not the case then some devices like BluRay Players can be changed from 1080p to 1080i mode to make them work on your 1080i plasma.
Check out my HDMI tip HERE for all you need to know about HD BluRay and interconnects
My Veon 32" tv wont turn on
Help my veon tv power is on sound is work but the screen is black ..i dont know what to do ?
Apr 19, 2013 | Televison & Video
Tip
Dont Make This Mistake With Your Lcd Tv Set!
Ok lets just say you wake up one morning and the screen on your lcd tv set does not want to turn on, outside it is cold.The tv set turns on but the screen does not, turn off the tv set leave it like that for acouple of seconds turn it back on and your tv set should be up and working, if for some reason this is not the case try it one more time just to see what happens.After trying the above suggestion your tv set does not work than the problem is the backlight, Thank You.
on Dec 18, 2009 | Televison & Video
Vizio tv gets only blue screen
The main board needs replacement very common issue. You can get a replacement main board from www.tvrepairworld.com
Jan 11, 2013 | Televison & Video
A black box randomly pops up on my tv screen constantly...
It part of the caption functions is on.Tries find in ur tv menu,goto captioning functions like CC1,2,3 and Text 1,2,3.Turn it all off.These radom black boxes and trying typing somethings,should stop.
Jul 20, 2010 | Olevia 237T 37 in. LCD TV
Blue screen red lock
I dont have a clue what happened...
The screen is blue and has a little red lock on the upper left hand side...
remote only works to turn it on...no other buttons work.
Help please!!!
Apr 01, 2008 | Insignia IS 20" TV040919 TV
Shatered screen
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Mar 25, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Tv dont work
check fuse in back of tv behind lower panel right where power cord gose in to tv
Feb 28, 2008 | RCA P61930BL 61" Rear Projection...
Screen blank
use the towell trick! Wrap the 360 in 2 towells turn on and leave running for 15 minutes. It gets very hot but after the 15 minutes turn off the console and power it back on again and it should work. Dont know if this is a permanent fix but my 360 hasnt broken again so far. Dont ask me how but it works, google it if you like. It also cures the 3 red lights problem.
Jun 22, 2007 | Microsoft Xbox 360 Console
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
24 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
