Question about Apple PowerBook G4 Mac Notebook
Shuts down and does not want to turn on - Apple PowerBook G4 Mac Notebook
    Guru:
  • 528 Answers
Hi pperuchett. Resetting the power manager of your precious powerbook G4 is needed to resolved this issue. I have provided you a link also on how to resolved this issue for better understanding. Please click here.
Posted on Jun 01, 2010
  • 7 more comments
  • pperuchett Jun 01, 2010
    I HAVE THE MAC NOTEBOOK.
    IT COMES EVERE 10 SECONDS A WINDOW THAT ASK ME WHAT I WANT TO DO
    SHUT DOWN RESART TO SLEEP OR CANCEL.
    THE ONLY WANT THAT I CAN USE IS CANCEL IF NOT IT TAKES ME DAYS TO BE ABLE TO START IT
  • Archie Cruz
    Archie Cruz Jun 01, 2010
    Did you click the link that i have provided to you. Is you computer included in the list? The procedure on how to rest the computer is in the link.
  • pperuchett Jun 02, 2010
    THE MAC NOTEBOOK ASK ME VERSION 10.5.8
    ARE YOU SURE YOU WANT TO SHUT DOWN YOUR
    COMPUTER NOW?
    RESTART SLEEP CANCEL SHUT DOWN
  • Archie Cruz
    Archie Cruz Jun 02, 2010
    Select Restart.
    IF I PICK ANY OF THE ABOVE (EXEPT CANCEL) THE COMPUTER TURNS OFF AND DOES NOT WANT TO TURN BACK ON FOR DAYS!!
    ! SO I LEAVE IT ON BUT IT GETS TO HOT SO I HAVE TO EVENTUALLY TURN IT OFF.
    IF I CLOSE THE NOTEBOOK IT TURNS OFF TOO.
    THE SOLUTION THAT YOU SEND IT IS NOT GETTING THE WINDOW THAT ASK ME THE QUESTION OFF (ARE YOU SURE YOU WANT TO TURN OFF YOUR COMPUTER NOW?)
    IT KEEPS POPING OUT EVERY 10 SECONDS AND I HAVE TO ANSWER CANCEL TO BE ABLE TO CONTINUE USING IT,
  • Archie Cruz
    Actually, you should turn off the computer inorder to perfrom the troubleshooting procedure that apple has provided. Please troubleshooting steps below.
    PowerBook G4 (15-inch 1.67/1.5GHz)
    PowerBook G4 (17-inch 1.67GHz)
    PowerBook G4 (15-inch Double-Layer SD)
    PowerBook G4 (17-inch Double-Layer SD)
    1. If the computer is on, turn it off.
    2. Disconnect the AC Adapter and remove the computer's battery.
    3. Press and hold down the power button for 5 seconds and then release the button.
    4. Reconnect the battery and AC Adapter.
    5. Press the Power button to restart the computer.
    Yes! it turns the computer on.
    Now how I can eliminate the window that comes up asking me if I want to turn the computer all the time
  • Archie Cruz
    Good to know that your computer is now turning on. Now, inorder to get rid of that message is to restore your computer from original factory settings. You will be needing the CD/DVD restore disc to do this. Take note that if you will be doing this procedure, all your documents and important files on your computer will be erased. Make sure to create a back up first before you proceed with the restoration.
    ok thank you!
Which parts should be changed to solve the problem not to automatically shuts down
It depends on why it is shutting down. Is it overheating? Is it full of dust or pet hair? Does it shut down normally showing you a shut down screen or does it merely turn off. If it turns off, then I would check fans and heat pipes. IF it shuts down with a shut down screen you would want to check your windows install.
Oct 16, 2016 | Computers & Internet
I have a Gateway Solo Pro 9300 laptop. Whenever I shut it down, the power light turns orange, and the backlight is still lit. Other than that, the hard drive and fans turn off. What does this mean. How can...
That means the computer is in 'Sleep' mode. To completely shut down the laptop, you can press the power button once and it will do a normal shut down.
May 08, 2011 | Computers & Internet
PC shuts down. When you turn on the pc it shuts
try to change the source, that should solve the problem. But before try reset CMOS. (if you don`t know how to do it by jumper simple remove the battery from the mainboard for 5 minutes and then plug it back on..and after that turn on your computer and press F1 for default settings)
Oct 27, 2009 | E-Machines eMachines Desktop PC
How do i shut down my think pad? it will not cut off
In your case,
the most simplest way to shut down your laptop is to override your processing by simply holding down the shutdown button until your computer turns off (do this when all your work is saved and the "Windows is shutting down" mode is on your screen).
This idea is not recommended but will always work.
Hope I helped
- donman92
Jun 03, 2009 | IBM ThinkPad T30 2366 Notebook
Shuts down during warm up
the fuser unit is not warming up, so the machine shut down
Mar 21, 2009 | Xerox Office Equipment & Supplies
Rear lights will nt shut down when I turn my vehicle off
try pullin up on the brake pedal with someone behind to see if they go out it maybe your brake ligts and the switch for the pedal is out of adjustment
Dec 09, 2008 | 2005 Chevrolet Impala
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
Tv shuts down
does the main board have the flyback on it? if so the yokes or CRTs can be intermittently shorting which in turn triggers your shut-down.
turning it off or unplugging just resets the shut down circuit.
Sep 04, 2007 | Samsung HL-R4266W 42" HDTV-Ready...
NP9890 shut down
If it is an overheating problem try turning the laptop off, turning it over and placing a vacum on the fan grill on the bottom. Many laptops get a dirt buildup internally and this will sometimes suck out the dirt.
Jul 29, 2007 | Sager NP9890 Notebook
Apple PowerBook G4 Mac Notebook Logo
64 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
