Question about Optoma EzPro 739 Multimedia Projector
My projector has vertical lines on display; what are possible causes of lines. Projector was dropped, I reinstalled lamp, lines went away for a while, now they are back.
  • Anonymous Mar 14, 2009
    the projector screen throws one white light in the middle of the screen
  • 563 Answers
Hi there
This is a common problem on a faulty Mainboard of a Projector.
Not much you can do about it except repair or replace the Mainboard
Posted on Apr 10, 2008
Why is there vertical lines on a smartboard UF65 projector?
1,white spots appeared on screen,means the DMD chip is
broken,you need a new DMD chip.I supply the DMD chip and the
price is USD120
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel,
Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
any questions, feel free to contact me
have a nice day!
Email/Skype: lampdeng@hotmail.com
Aug 11, 2014 | Smartboard Smart Board UF65 Projector Lamp
What causes white vertical lines on dlp projector?
Possible fault on the mother board as there are noise on the LCD display. You might need help to sort this out if the fault does not clear even after the lamp works for some times.
Nov 05, 2011 | InFocus ScreenPlay 5700 Multimedia...
I have vertical lines on my display - how do I get rid of them?
try loosening the screws that hold the lamp in, there is a possible short in the encasement.
Jun 07, 2010 | Dell M209X Ultra Mobile Projector ...
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
X2 projector A somewhat irregular vertical line has appeared near the middle. A slight rainbow affect at the line, right of the line gets progresively darker. The blank screen is normal. The projector is...
this projector does not have lcd's. it has a colorwheel and a light tunnel. the light tunnel has probably collapsed and needs to be replaced if you have distortion in the middle of the display. if it were to one side or the other or a the top or bottom it may have been adjustable. But wiith it being in the middle, I'd have to say you needed a new light tunnel.
Mar 12, 2010 | InFocus SP-LAMP-018 Projector Lamp for X2,...
Sanyo lcd projector has horizontal scrolling lines in its picture. Is this different than a lamp problem? Electrical? All else works fine. Thank you. Sanyo PLC-5600n lcd video projector. Not a tv.
This is caused by the processor and not by the lamp. As you might know, these projectors display colors by blanking out the light with lcd pixels. Most folks don't know that any display devices such as displays on cameras, laptop displays, etc. use an amazing amount of original technology that powered CRT TVs. (Yes, even vertical hold, although done electronically today, is there.) You'll just have to send this one in for service.
Feb 26, 2010 | Sanyo Televison & Video
Infocus X2 projector, white vertical strip on right quadrant.
on the X2, the dmd chip is attached to the main board on the bottom of the machine. you need to take the top case off, as well as the 2 power supply boards. push the dmd chip (behind the lens assembly) back onto the board.
Jun 04, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Vertical line white, regular, blinking.
I don't think it's the bulb. Sounds like an LCD panel issue. Maybe one or more of the 3 LCD panels is either not working right or the unit has been dropped/jarred and the panels have moved (All three have to line up right optically to give the right colours). You need to take the projector to a qualified service centre.
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Apr 01, 2009 | Acer Projector Lamp for PD110, PD110z
Lp70+ display shows a solid black vertical line
the light tunnel is either collapsing and blocking the light going through it (and needs replacement) or the vertical/hoizontal adjustment of the tunnel. if you take the lamp out and move the colorwheel (with a pencil eraser) to the clear section, you should be able to see a square through it. if part of the square is blocking the middle, the tunnel needs replacing.
by the way, on some projectors the light tunnel is called an integrator rod.
Jun 17, 2008 | InFocus LP70+ Multimedia Projector
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
Open Questions:
Optoma EzPro 739 Multimedia Projector Logo
1,258 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
