Question about Honda Karcher G2400HH-R Pressure Washer
No pressure on Honda 2400psi pressure washer
This is a 4-year old barely used machine. It got the problem last year. It dropped the pressure in the middle last year; now it totally loses the pressure. What might be the problem?
    Problem Solver:
  • 8 Answers
Spill valve aka unloader valve is stuck needs to be cleaned and lubricated with grease re instaled
Posted on Jul 28, 2010
Pressure washer will not prime
check check valves for obstruction they are normally underneath the hex caps
Aug 13, 2014 | Powerwasher 2400psi 2.0gpm Pw2420 Gas...
What type of oil to use
for the motor you need to go by manufacturer's recommendation most pumps use 30w non-detergent oil with the dip stick screwed in
Oct 14, 2012 | Powerwasher 2400psi 2.0gpm Pw2420 Gas...
Do you use 4 cycle oil or 2 cycle oil for pressure washer EXH2425?
For your model pressure washer you should not be using 2 or 4 cycle oil. You need to use the following:
Model # EXH2425 P 2400PSI 2.5GPM 5.0HP HO
PUMP TYPE OIL TYPE OIL CAPACITY
**Annovi Reverberi (XMV) 30W non detergent 13.5 oz.
**Annovi Reverberi (RKV) 30W non detergent 18.54 oz.
Aug 15, 2011 | Garden
I have a Honda GC160, 2.2gpm, 2400psi pressure washer. How much and what kind of oil do i put in the pump? I wasn't getting much pressure so I pulled the pump apart.(bad move)
We are talking about the water pump here right . A stright 30 weight and it for that size pump about 14 ounces .4 liters look at the little window on the pump on level ground it should be at the half way point . If you want to buy offical pump oil the # is AW-4085-0016 This is MI-T-M spec but with this # you should be able to cross refferance to your pump make in case there is an issue with detegent or non detergent oils it could be an issue for the seals . But its basicaly 30 weight oil
Jul 07, 2011 | Honda Garden
How much oil does the coleman powermate 2400psi with a honda engine hold
Use only the quantity specified in your pressure washer's manual for your pump. If you're not sure, measure how much oil you drained and replace with that amount. Most pumps have an oil window or sight glass on the side of the pump, with a mark or red dot indicating the proper level for the oil.
Read more: When Should I Change the Oil in My Pressure Washer Pump? ' eHow.com http://www.ehow.com/way_5873362_should-oil-pressure-washer-pump_.html#ixzz1JusLIVOu
Apr 18, 2011 | Garden
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
OUR KARCHER 2600 PSI PRESSURE WASHER W/ HONDA ENGINE WON'T START. WE BOUGHT IT A SAM'S CLUB LAST YEAR AND PROBABLY HAS ONLY BEEN USED ABOUT 4 TIMES. PLEASE ADVISE.
Hello:
Have you tried changing the gas, Especially, if it has been in the machine of a while. Also some Honda engines will not start if the oil is low. Also try removing the high pressure hose before you start it? Do not run it very long without water flowing through the pump, though.
Sep 20, 2009 | Karcher Garden
Can't start the Honda GX160 5.5 HP Electric motor on my Chore Master 2400psi Pressure Washer. Got gas (checked through feed line), new spark plug, switch on, gas, choke ok, throttle a bit funky (about 12...
Is there an oil sensor unit if it is going bad it tells the engine the oil low and engine wont start. I had same problem with my pressure washer, i just unplugged the sensor unit and it started fine ever since
Apr 27, 2009 | Garden
Honda 2750i Powerwasher
I had the same problem 3 years old, maybe used 10 times - removed the air filter and the washer started fine. The air filter looked fine - I have not tried to replace it or figure out the root cause. I was just happy to get it running again :)
Aug 09, 2008 | Karcher 2500 PSI Pressure Washer
Honda Karcher G2400HH-R Pressure Washer Logo
358 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
