Question about Dishwashers
Dishwasher won't access soap tray
Hey all. My kenmore quietguard deluxe dish washer is going through the wash cycle and never "activates" the soap tray. Since we've had it, we have used the newer "soap packets", and they;ve always worked...until now.
Help if you can. Thanks in advance!
  • 375 Answers
Check if the dish rack is reversed. If it is, it'll block the dispenser from opening.
If that is not the case - you may have problems with soap dispencer solenoid or with control board. Unplug the d/w. Disassemble the door, and find the solenoid contacts on the dispenser. Check for continuity. No continuity - replace dispenser.If dispenser is ok, check wiring for continuity. Otherwise it's the board.
Posted on Jun 01, 2010
Dishwasher soap is not dissolving.
Try emptying the dishwasher and putting a few tablespoons of vegatable oil in the bottom. Run the cycle without soap and no dishs. Often dish soap (palmolive) builds up and creates soap suds that won't go away during a normal cycle. The oil binds with the soap residue to get rid of it. It worked for my Kenmore. I know do it every few months. Good Luck!!!
Thanks
Jun 22, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Kenmore Ultrawash Quietguard Deluxe Problem
kenmore washers nothing but problems, my washer says clean and will not do any cycles...... less that 2 years old
Oct 21, 2009 | Kenmore Dishwashers
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore 74362
I had the same issue and you will never beleive the solution.
Steps to follow:
1) run one full cycle with no dishes or soap
2) run one full cycle with a dishwasher cleaner like Jetdry
3) run one full cycle with a gallon of white vinager
4) never put soap in the extra in and only fill the main soap bin half way.
should work fine from here on out, but never fill main bin more then half way when you do dishes. also run the hot water in the sink until the water is very hot before starting the dish washer.
Dec 19, 2008 | Dishwashers
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Despenser cup - Kenmore dish washer
hi
the dispenser will always open when the washer goes through it's regular cycle. I would recommend to only use powdered soap, that is what the washer was designed to work best with.
Mar 20, 2008 | Miele 24 in. G892SCU Plus Built-in...
"Sensing" Light
There is a relay on the soap dispenser, if it is a Kenmore quietguard 4, I had the same type of noise, the repairman replaced the dispenser, which to me made no sense, because the relay is activated from the control board. After the $130. for the soap dispenser, he ended up replacing the control board for another $160. Now the dishwasher only goes up to the dry cycle and stops. If you press the heated dry button and then the heated wash button 5 times each, the entire control face will light up and it will do some kind of reset and try a new cycle. I have tried the button pushing and it worked great till it got to the dry cycle, so I am looking for another solution without involving Sears. Good Luck!
Jan 17, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
144 people viewed this question
Top Dishwashers Experts
