Question about Sharp AR-M237 Copier
Adapter for scanner - Sharp AR-M237 Copier
  • 328 Answers
It doesn`t have scaner.
Posted on Aug 10, 2010
What power supply is needed for hp scanjet 2400
It is depends on your scanner power adapter and where u purchase the scanner from. Here if your scanner is from US then the adapter power input should be 100-120V 60Hz AC, if your scanner is from Euro, UK or Australia, the it should be 200-240V 50Hz AC, while if your scanner is from others place that not listed above then it should be 100-240V 50-60Hz AC.
But the best way is look at your adapter itself, u'll notice the power input and output from the adapter sticker.
If you lost your adapter then be sure to purchase 1 that can output a 12 VDC, 340mA, 4.22W adapter to the scanner.
YBC (/\)
Oct 20, 2009 | HP ScanJet 2400 Flatbed Scanner
Slip adapter is part of the scanner ? How to use slip adapter to scan negative film ?
The film goes into the adapter and the adapter mounts on the underside of the lid.  Complete manual available free at http://www.scribd.com/doc/7571067/HP-Scanjet-G3010-Users-Manual
May 21, 2009 | HP Scanjet G3010 Flatbed Scanner
Scanner stopped in the middle of a scan
Although I can not be sure without testing it, the most common problem with this type of issue is that the power supply adapter has failed. According to the manual (posted at http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00215714/c00215714.pdf) this scanner has an external power adapter. Since you indicate that the scanners light does not come on, I would be inclined to believe that power adapter needs to be replaced. However, before you go and buy a new one, I would suggest you get the current adapter tested with a volt meter to determine if it is outputting the correct voltage and amperage.
If you discover that the power adapter has failed, you may be able to simply replace it in order to get the scanner up and running again. However please take note that depending on what part of the adapter circuit failed, its failure could possible have also damaged the scanner's internal circuits. However, if you find after testing that the adapter is outputting the correct voltage and amperage, then the problem would most likely be a scanner board circuitry failure.
May 04, 2009 | HP ScanJet 4600 Flatbed Scanner
Scanner not working
Adaptor rating should be 5.25amp 240volt
ITE or Phihong brand are normally used on this unit.
Main board drawing to much current.
check for staple contamination inside scanner.
Feb 16, 2009 | Kodak i160 Path-Through Scanner
Need Replacement AC Adapter for Epson V200 Scanner
I have an Epson AC Adapter 220volt/13,5 Volt. Model A391VD As my scanner broke down. Fell from my table.
Feb 08, 2009 | Epson Perfection V200 Flatbed Scanner
Power won't turn on at all.
would suggest to start testing at the power adapter if the power adapter is not working properly you will need to replace it with a matching power output adapter or exact same model if you can find.
if the power adapter is not the problem, its probably not worth the repair, up to you, I haven't looked into your scanner to see if its valuable or not.
Well a new scanner / all in one printer with a scanner goes around 50usd.
Jan 05, 2009 | Visioneer OneTouch 8650 Flatbed Scanner
Power supply
The Umax 3400 scanner uses an adapter with 12 volt 750mA output.
You can see it / buy it ( $11.95) on the UMAX website.
Just Google: umax scanner power adapter
Aug 24, 2008 | Umax Astra 3400 Flatbed Scanner
Pro 97 Handheld - Adapter Issue
I have the same problem with my pro-79 scanner. The adapter from my Uniden cordless phone works on my scanner, but then the phone won''t work.
I have rechargeable batteries but they don't stay charged very long in the scanner. I know this didn't solve your problem but thought I would let you know about the cordless phone adapter.
Jul 28, 2008 | Radio Shack Pro-97 Handheld Scanner
Scanner has no power
This issue could be due to two reasons 1). The power adapter of the scanner could go bad and needs to be changed, and the other the Scanner it self is gone bad, however you can try few steps given below.
1. Remove the scanner power adapter and clean the metal contacts on both the ends also clean the metal contacts on the scanner as well if possible.
2. Reseat the power adapter on both the ends.
3. Plug the scanner to a different or known good power source
4. Disconnect and bypass the power extensions if used and connect the scanner directly to the wall jack.
5. Try a similar know good power adapter.
Regards
Malik Khan
Jan 31, 2008 | Epson Stylus Color 750 + Perfection 1200...
Coolscan ed 4000
The scanner has a lock which locks the film adapter into the scanner when film is inserted. You probably still have film in the adapter from the last time you used it. If the adapter is pulled to remove it, the connector can become disconnected, which prevents the film from coming out, but the latch is still engaged. With the scanner off, push in the adapter to mate the internal connector. Turn the scanner on then off, the film should eject. Once the film is ejected, the adapter should be able to be removed. Refer to your manual for reference to this problem, I have experienced once before. Once you figure it out, you will not forget, I guarantee.
Aug 15, 2007 | Nikon Super Coolscan 4000 ED Film Scanner...
Sharp AR-M237 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
