Question about GE Refrigerators
We have a side by side GE. The freezer freezes solid and then the cool air can not travel up the back side to the frig and the frig get really warm. Can we shut off the freezer and still have the frig work? We have had the computer panel on the back, the ice maker arm motor and the defroster coil all replaced. I will not put any more money into it. Could it be that the flap on the front of the door to dispense ice doesn't seal completely?
    President:
  • 1,561 Answers
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater . It is also advisable to replace the defrost thermostat when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it. It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off .
Take care.
Posted on Jun 01, 2010
The engine is still running, but the frig is warm a friend turned the timer and the freezer is freezing now, but the frig is still warm. Do I need a new timer?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer goes through a cycle and get warm. The ice will start melting and create a mess when the freezer start to cool agian. Temperture in frig and freezer does not hold cool.
Unplug, empty, clean and let set for 24 hours to defrost the cooling coil that is froze solid overwhelming the heater and not letting it work. if the air can't circulate it will not cool. Check door gasket, or tell kids to stop holding the door open as this will cause it to frost up and cause the problem you're having.. Trust me, It works.
Jun 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our ge refrig runs constantly,freezer is freezing but the refrig is not cooling. I cleaned the dust and dirt out of the bottom and back of refrig.
See if the fan in side the frig is working It mite be on the freezer side If the fan is not working it will not blow the cold air in to the frig side
Jul 12, 2009 | Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Warm refrigerator cold freezer GE side by side TFX24ZH
Check air passage between the freezer and refrig. compartment for a blockage (condensation freezing )
May 13, 2009 | Refrigerators
Bottom of frig freezes, top is 60 degrees
Check your door fit. The gasket should be tight all the way around, you can push the door back into shape.
Apr 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side not cool enough even on higher settings
I posted this on another problem, but this may help you too.
Check to see if there is frost on the back panel of the freezer.
If there is try solution below:
I had a similar problem. The frost in the back is an indication that your coils are frozen. This could be from food packages falling out of the freezer drawers in the back and blocking the air circulation vents or maybe the freezer door was not closed completely and letting moist/humid air in and freezing the coils.
For me it was the first problem listed.I had to completely empty the freezer and Frig. and take the back panel off in the freezer. There you will see the coils and lots of ice!
1. Remove all items from the frig. and freezer and unplug frig.
2. Pull all the freezer drawers out.
3. On my GE side by side I took the light cover off and removed the bulb. There you will see two panel screws. Remove the screws.
4. Now pull out the mouldings on each side and you should be able to remove the panel.
5. Take a hair drier and completely defrost all the ice from the coils.
Be sure to keep plenty of towels handy for all the water mess. Remember to keep an eye on the drain tray in the back of the frig. and use a sponge to collect the water that will build up.
Hope this helps!.....
Woody
Mar 29, 2009 | GE GSS20IEP Side by Side Refrigerator
FRESH FOOD SIDE OF FRIG NOT COOLING
i would take the back freezer panel off and see what kind of frost pattern your coils have.they may be frosted over and the begining of a defrost problem.
Mar 11, 2009 | GE GSH22KGM Side by Side Refrigerator
Refrigerator side too warm
SHOULD HAVE A AIR DIVERT ER CONTROL TO SEND MORE AIR TO FREEZER AND LESS TO FRIG SIDE TRY TO SENT MORE AIR TO FREEZER SIDE AND LEAVE COLD CONTROL COLD ENOUGH TO ACCOMMODATE THE FREEZER SIDE TO BE COLD ENOUGH
Jan 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
