Question about Hoover U6311-930 Power Drive Bagged Upright Vacuum
How do I make my vacuum get unclogged - Hoover U6311-930 Power Drive Bagged Upright Vacuum
  • Hoover Master
  • 43,501 Answers
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Posted on Jun 01, 2010
How to unclog a bissell proheat pet carpet cleaner
There are a few at home remedies you can try. White vinegar can be used to disinfect and unclog the cleaner. I would suggest running it through a few times. However if that doesn't work, there are supplies you can buy to unclog the carpet cleaner.
Elisa Jed ' http://www.missionimpossiblecleaning.com.au/services/
Jun 27, 2014 | Vacuums
How to unclog a bissell proheat clearview carpet cleaner?
Check your User's Guide for filter locations. Bissell Consumer Care 1-800-237-7691
Jun 23, 2014 | Bissell 1699 ProHeat Clear View Upright...
Vacuum is clogged
Without specifics of Model, I can't tell you how. There are no clog ports in Dirt Devil vacuums. Usually a hose has to be removed to unclog.
Apr 05, 2014 | Dirt Devil 12 Amp HEPA Filter Vacuum...
My hoover has no suction. How do you unclog the hose?
get an old wire coat hanger and straighten it out and unclog you pipe.adrian,,,,
Jul 07, 2010 | Hoover Company Wind Tunnel U53019 Upright...
I have kenmore progressive and it is clogs is there a way to unclog it
The easiest way we unclog this machine is to take another canister vacuum and use its' hose to put on the hose of your machine then switch it on and **** the clog out of your machine. Works great.
Dec 01, 2009 | Kenmore Vacuums
Hose that releases the water and cleaner on my Hoover is clogged
Your right the hose is clogged.. Use a portable vacuum to blow the dirt inside the hose.
Jul 24, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Does not have the same suction as when we first purchase the vaccuum. it is only 2 years old. We cleand the round filter at the bottom of canister. Any suggestions?
Sounds like you have a clog in the hose or from brush to the hose. To clrar turn vacume over and remove bottom cover to unclog where it meats the hose. I would use a coat hanger to unclog the hose.
Dec 16, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do I unclog a bissell vaccum? I'm not just talking about unclogging the hose, I need to unclog the complete vacuum cleaner. HELP!!!
Well firstly, whats the model number and do you have the user manual to hand?
If the main hose has been unblocked, then it could be the main dirt channel which is blocked just after the moving roller brush panel. A long pipe cleaner or wire brush can remove this blockage easily rather than taking everything apart.
Apr 18, 2008 | Vacuums
BEAM Serenity Plus 2900 has shutdown
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. OK, there is a reset button on the unit but i think it could be that your vacuum could be clogged in the vacuum lines and that you should check all the inlets/outlets in your house with your vacuum hose - or get a vacuum cuff and go to each individual outlets and check the suction by feel - if the outlet is clogged you may have to call someone to unclogg it or by going to each oultlet the system may unclog it self -- or you can use a plumbers snake and be careful because the lines in a central vacuum are thinner than the walls in a plumbing situation or have it professionally unclogged by a priofessional. When you are using another vacuum to unclog the unit make sure the central vac is runing and to try to pull the clog apart from both directions. Below is a link to the factory for Beam and if you need a owners manuel for the Central Vac
http://www.beamvac.com/usa/
Sep 30, 2007 | Beam Industries 2900 Serenity Plus Central...
Hoover U6311-930 Power Drive Bagged Upright Vacuum Logo
118 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
