Question about Coleman (5040B750) Patio Heater
My patio heater is cutting out affter several mins, what do you think it could be
Can i bypass the dump switch on my patio heater
No, everything on it is there for a reason. If it blows up and shatters all your windows and fries your kids is that OK?
Feb 06, 2016 | Plumbing
Patio heater fell over and now not working could it be the flame screen needs to be replaced
????????????????????????? Whatevers Broken / Damaged needs replacing
Mar 14, 2015 | Patio Heaters
My iHeater shuts off
Our heater cuts off after 2 mins or less and it shoe 90 on the temps diplay. Had it for a couple of years. It's been vacuum and clean and still the same results. I don't have the schematic or the owners manual..
Jan 17, 2014 | IHeater 1500 Advanced Infrared Heater...
My brand new patio heater wont turn on
To get your patio heater to light first check the tank has plenty of LPG/gas and the regulator is turned to on. Next turn the gas control knob to pilot (on some heaters this is a red line on others it has a spark symbol) and press in - hold for at least 30 secs. Press the piezo ignitor several times and continue to hold for another 60 secs. Gently ease off the pilot to release and turn to full power. You should hear the gas jet come on. If there is air in the pipes you might have to repeat. Fould this site very useful patio heater top repair tips.
Apr 10, 2012 | Heating & Cooling
How to change a thermocoupler for a Bluerhiono charmglow patio heater?
Hi, All patio heaters are not the same, the thermocouple can be wired up in several different ways. If you have a branded BFX750 or BFX770 patio heater it is a simple task but for a Bluerhino heater you will need to ask the supplier for instructions.
Oct 10, 2011 | Heating & Cooling
The lid on our Endless Summer Patio Heater 200209 is bent. Can it be fixed? If not, where can I purchase a replacement?
If you are referring to the heat deflector top on the upper most portion of the heater. yes, it can be repaired , if it is not to severely bent. It would require removing it from the heater to straighten it. If the metal is creased, it's not worth repairing.
Blue Rhino is the manufacturer for Endless Summer Patio Heaters, as well as several other brands. You can contact them for replacement parts @ 1.800.762.1142
Jul 06, 2011 | Endless Summer 200209 Open Flame Patio...
Coleman (5040B750) Patio Heater Logo
81 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
