Question about Nokia N95 Cellular Phone
Hi I have N95 and when i plug charger in it says not charging can anyone help
I'm having the same problem w/my nokia!!! I think it's just time for a new damn phone or a repair atleast. The charger that came with my N95 isn't here w/me but my backup charger that i bought off e-bay IS which doesn't work. So NEVER BUY CHARGERS ANYWHERE ELSE BUT THE PHONE PLACES! FML and my phone and/or charger because i have to use an old Samsung FLIP and I'm going to a club tonight. =(
GOOD LUCK GUYS!
Ps: It can also be your battery, so you might wanna go in and check if you need a new one. And keep in mind, only charge your phone if you NEED to.
Posted on Sep 10, 2010
    President:
  • 1,561 Answers
The problem could be that your charger is malfunctioning or low current.
I advice you try using another similar charger to charge your phone to see if it is not the charger that is malfunctioning because when charger is malfunctioning, phone reads not charging.
Secondly, ensure the power supply is stable and not on low current because when current is low, the charger will not be able to charge your phone and the phone will read not charging.
With the two above information of either malfunctioning charger or low voltage will solve your not charging problem but if not then it means the charging port of your phone is bad and will need to be replaced in other for your phone to charge.
I advice you check the power supply first to makesure it is not low, use another similar charger to charge your, if this two did not solve the problem, then it means it is the charging port and will need to be replaced.
Take care.
Take care.
Posted on Jun 01, 2010
  • 85 Answers
Hi, is it the charger that came with the phone? if yes maybe its not properly connected, try re connect it.. but if it a new charger you just bought, i guess its not compactible with the phone that is why its not charging..try get a nokia approve charger
  • 269 Answers
Please check the charger by plugin with some other nokia handset and check if the charger is working fine. If still it shpws not charging with other handset then change the charger as charger is not working
96% plugged in, not charging Hi all, my Asus
Laptop battery do have a specific lifespan, specially for older units. Still, you can check that your charger are working properly, using a voltmeter (do check the outer label of the charger for actual voltage output).
You may try to do my Tips on Laptop battery
Good luck
Tedmac
Oct 17, 2013 | ASUS Computers & Internet
I have N95 and i have being charging for more than 14 hours but it still not changed.i try new batterys but it still the not charging can any body help me.thanks
hi there!
14hours! its not the battery then. try other chargers, if none of them worked, plug one working charger, try moving the plug jack (make sure its pushed all the way to the phone's charging port) wiggle it, see if the battery level changes. the contacts of the phone can be damaged too. its a hardware issue meaning a local technician is the best thing for this .
Apr 08, 2011 | Nokia N95 Cellular Phone
My nokia n95 wont turn on even when charger is in phone in mains i havent used phone for a while because the battery died quickly even when i hadnt spoke to anyone
better you go to nokia service center make a good check up or try by replacing with nokia s original battery and charge for it continusly for upto 6 hrous with out switch on the phone ..... try it
Feb 02, 2010 | Nokia N95 Cellular Phone
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
Dec 11, 2009 | Nokia N95 Cellular Phone
Nokia N95 8gb. will not charge or power up.
That phone does charge using the USB port like other phones do. You have to use the 5v Nokia Charger that comes with the phone; it should plug-in right next to the USB port.
Mar 08, 2009 | Nokia N95 Cellular Phone
My nokia N95 is no longer charging
It could be the charging unit on the bottom of the phone.Check for discolouration like green mould or rusting.If this is present you phone is moisture damaged and cannot be fixed.If this is not there bring it to your network to get repaired.But before you do that try a different charger with your phone as sometimed the fuse in your charger could be gone.hope this helps
Dec 04, 2008 | Nokia N95 Cellular Phone
My phone nokia n95 losses its battery charge every 3-4 hours
Its time to replace the battery. Also check that the charger is working properly, and the contacts on both the phone and the charger are not oxidised. If they are, try scraping the contacts gently with a sharp object like a jeweller's screwdriver , etc..
Oct 25, 2008 | Nokia N95 Cellular Phone
N95 is dead and wnt charge
It could be a software problem. Try performing a master reset or firmware update.
May 30, 2008 | Nokia N95 Cellular Phone
Charging problem..
There is a Charging fault in your N95. It is advised to go for a repair. To charge your battery use UNIVERSAL CHARGER to charge it... You can find these kind of charger easily...
OR use another Phone to charge your battery...
Plz Rate Me.
Thanks.
May 11, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
240 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
