Question about Toshiba 27A34 27" TV
Trying to hook-up a dvd player
I have a dvd player properly connected to the TV, but I cannot figure out how to get it to play on the screen. I have tried all the channels. I programmed a universal remote to the TV, which does not have an input button. Could this be the problem? or is there some other way to get it to play?
  • Anonymous Jan 25, 2009
    My universal remote has an input button, but that isn't working either. My ex had used this tv and thinks he had it first hooked up to a VCR, with the DVD somehow connected to that and he didn't have a problem using the DVD player.
    I have no idea what that means though!
Its because the tv you have is ***, we are in 2009 and there is something out there called technology...get rid of that crummy *** tv and buy yourself a HDMI 1080i tv or sumething bubba
Posted on Aug 07, 2009
5 Suggested Answers
6ya staff
SOURCE:
Cybertech
Jose Zetino
  • 149 Answers
SOURCE: no input button
go to localtv shop try getting a used remote for your tv remote original no longer available and is what you need
Posted on Apr 01, 2008
Steve W
  • 104 Answers
SOURCE: Can't find the input/video channel for my Emerson TV
universal remotes are tricky, if you have the pamphlet, often times there are several codes for each brand. you have to try all the emerson codes for your universal even tho the power, volume and channel functions may work with several emerson codes, some of these specialized buttons (like input) may only work on your TV with one specific code.
also, if there are any unlabeled buttons on the universal try them with each new emerson code.
Posted on Feb 12, 2009
Anonymous
SOURCE: DVD player hooked up, no auxilliary channel
I also have this ******* problem and apparently there is not solution. So just remember, next time you wanna find the urge to buy a ******* sanyo...dont do it. Sanyo = Bigfoots ****!
Posted on Jul 14, 2009
Robert
  • 176 Answers
SOURCE: I have a philips I got from a hotel but i cant
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Posted on Jan 15, 2010
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
I cannot figure out which RCA jack output do you plug the jacks into to hook up a dvd player?
AV input wire will have three connections. Red, Yellow andWhite. Out of which, Yellow one should be connected to Video Out of the DVD player, and the other two, Read and White; to be connected to the audio out left, and audio out right of the DVD player. The other ends of this wire should be connected to Video In, and Audio In socmets of the TV. Keep trace with the colour of the socket and connect it. Select the Input of the tV to AV. Switch On both the devices. If the connection is correct, you will see the logo of the DVD player on the tv screen.
Mar 19, 2012 | iLO IWT3206 TV
I'm trying to hook up my dvd player to tv and don't know where the cables on the back of the dvd player should be????
RCA cables:
connect yellow on DVD to yellow on TV. Connect white (next to yellow) on DVD to white on TV.
OR if you have HDMI cable, connect HDMI on DVD to HDMI on TV.
Insert DVD, press PLAY.
Select proper TV input using TV remote. Cycle thru (Select input or Video etc.)
Mar 04, 2011 | Televison & Video
DVD won't play with Direct TV
Finally............. monkeying around with the remotes, we discovered the basic little remote that turns on our TV was the source of connection. We now hit AV twice, and Go Video works. Voila. It took quite a bit of time to try every possible angle, finally realising we needed to leave Direct TV Remote out of the equation. Just the Go Video remote and our basic little simple remote. Go figure!!!!!
For now, we are good. (knock on whatever:)
May 27, 2009 | Cyberhome CH-DVR1500 DVD Recorder
I just Cant figure out how to hook this DVD Video Player to my TV
You must give a clearer explanation of the type of television you are using and the type of cables you are using in the hook-up. You should give the television name and model number.The type of connections you are trying to use. What the problem is.Is a conflict between the remotes or just a user problem. You should find all reasonable hook-up information for you television in the owners manual. The same goes for the dvd player. Hope this helps you with your problem.
Apr 19, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD is hook up and no picture on the TV.
You have to make sure that the RCA cables are properly connected to the TV. Check the TV/Mode if it's set to AV1 (Audio/Video1) or AV2. You may check the TV remote to set it to AV1 or AV2.
From the DVD, the cable should be connected to OUT. And on the TV...video and audio should be connected to IN.
Apr 05, 2009 | JVC XV-S300 DVD Player
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
I can't seem to get my dvd player to play on screen
Set the TV to look for a signal on the same input your are hooking your dvd player to. Example, if your dvd is hooked to video 1, set the TV to show video 1 on the screen.
Dec 31, 2008 | Dell Televison & Video
Screen is green when trying to play a DVD
I think DVD player is hooked with TV via component video input.
Check component video connections and make sure each color wire connect in same correspondence color in both units, TV and DVD Player.
Red to red, green to green and blue to blue.
Dec 18, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
HDMI hook-up
Try scrolling thru the TV's video inputs. When you get the right one, the circuit will automatically recognize it and play provided it's connected properly
Jul 27, 2008 | Sony DVP-NS575P DVD Player
Toshiba 27A34 27" TV Logo
104 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
