Question about Car Audio & Video
I have a 2002 Ford Focus with a CDR 4600 radio. The radio has no audio output on the AM band. With the volume turned way up I can just hear a hiss. In the FM bands, when I first turn on the ignition with the radio on, I get good audio but at some time later the audio disappears. Leaving the radio on, later the audio will return for short periods of time. I have taken the radio out of the dash and turned it on with the same results. Jarring the radio when it is on or off seems to have no change in operation. One thing puzzels me, some times when I turn on the radio via the Volume push button, a display of "1hr" will appear for one or two seconds. This happens when no audio is heard. Any relation?
SOURCE: FM RADIO DONT WORK..MODERATE AM
if you installed an aftermarket antenna you may have to splice two wires to make full connection, email customersupport@discountautoantennas.com and explain and they may be able to email you instructions for a solution you may not have it grounded properly.
Posted on Mar 14, 2007
KaeZoo
  • 156 Answers
SOURCE: auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Posted on Mar 15, 2007
  • 46 Answers
SOURCE: 75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Posted on Mar 15, 2008
  • 3 Answers
SOURCE: JVC KD-LHX500 has power, but won't turn on!
Replace the 15 amp spade fuse in the back of the unit. See if that get you going again. If that doesn't do it then check your wirin Black goes to ground, Yellow is a constant hot, Red is a hot trough the fuse box, Blue is for your power antenna if you have one, the Orange with a White Stripe is to the Illumination and is also hot.
Posted on Nov 12, 2008
  • 20 Answers
SOURCE: 2007 honda crv radio will not work in am band
I worked for honda on the crv the antenna having a bad connection between the radio and antenna will stop am but you will still get fm.
Posted on Mar 06, 2009
How so i pick station on my Radio Shack police scanner?
I have never used a scanner of that type but I have seen them in use and know the principle of operation.
If you are certain the radio is working and have checked with the instruction manual that you are operating it the correct way with any squelch control turned down and the volume turned up there should be a loud hissing from the speaker indicating the radio is ready to receive as soon as it is either tuned to the specific frequency of a station by direct entry or by scanning one or more bands of frequencies.
If there is no hissing noise it is possible the audio output is faulty or the aerial is not connected or the radio is otherwise faulty.
If the hissing noise is present and powerful and still nothing is being received it is possible there is nothing to receive or a more powerful aerial is needed.
It is worth noting many scanners available in the past tended to scan bands of frequencies in the upper and lower vhf bands where the aircraft, marine and emergency services radios operated. Since those days many of those services have moved their communications into the UHF bands leaving the vhf bands relatively empty.
Oct 04, 2015 | Radio Shack Radio Communications
Code for a 2002 ford focus
Type in the 6 digit serial number then press button 5 on radio 'calculate code' to close the program press the volume button 'close program' to clear the serial press the seek button
Mar 07, 2015 | 2001 Ford Focus
No sound on unit
There are any number of reasons for no sound. I will assume you're using new batteries or fully charged batteries. The simplest reason is that a wire has become disconnected from the speaker. This would make the radio sound the same on as off. To test this see if the radio has a way of turning the squelch off, sometimes a simple push button, sometimes a menu setting, sometimes a dial to adjust the squelch setting. If there is no hissing, sometime very loud so turn your volume down first, then either the audio output amp is dead or a wire to the speaker is broken or disconnected. I today's radios the audio amp is most likely a simple small IC but, it could be inside an all-in-one chip and if it's proprietary getting the chip could be a problem. If it's a simple audio chip you'll have to find a replacement or rig up another audio amp IC to work as a replacement. Let's hope for the simple broken or disconnected wire which should be easy enough to fix.
Now, if when you remove the squelch you hear the hissing but you still cannot hear transmitting from your other radio, it could be that the one transmitting is in fact NOT transmitting an not that the other radio cannot hear. You have checked that both radios can or can not hear someone else's radio right?
Assuming you do know that one radio cannot hear what the other can and make no sound other than hissing when the squelch is off the problem is either in the RF or IF sections of the radio's receiver. In general this used to be a more complex repair so let's go another easy fix by going to the very first place the RF comes in, the antenna.
Just like the audio section when a speaker wire is disconnected sometimes the wire or trace going to the bottom of the antenna can become disconnected or broken. To check this bring a good transmitting radio very close to the one that hisses but does not hear the transmitting radio and see if any place as close as you can get the two radios causes the non-hearing radio to hear the transmitting radio. If so, then look for a problem with the antenna connection.
If none of these easy things bring the problem to heel then there's probably something amiss in the RF or IF receiver sections. If the radio has one or two chips that do all the work here then see if you can get both and replace them. I haven't even taken apart my own small FRS radios to see how complex the receivers are in these so I won't go any further than that since I simply don't know your radio.
I hope that helps.
Apr 07, 2014 | Radio Communications
Ford focus radio wiring 12v+ constant
Don't know the focus radio hookup, but on most cars, there are "two" hot lines. One constant to run the clock, the other on/off via the ignition. From what I read the one going to the ignition is staying "on?" Clarify
Aug 30, 2012 | 2002 Ford Focus
I have a problem with hiss coming from the sound bar (ZBase 550 HSD) when using my digital cable box. It is not an issue with PS3 etc. I have the sound on the cable box turned to max, but I still hear a...
Hello ZVOX Owner,
The hiss you hear is generated by the analog audio output of the cable box. The best way to eliminate this hiss to use the digital output of the cable box. The preferred way to do this is to connect the digital audio output of both your cable box and your PS3 to the your TV (I presume your TV has two digital audio inputs.)
Your TV has a digital audio output. You should connect the digital audio output of your TV to the digital input of the ZVOX.
This should reduce or eliminate the hiss and provide convenient video source selection via the TV.
From Fred P. at www.zvoxaudio.com
fred@zvoxaudio.com
Jan 27, 2011 | ZVOX ZBase 550 HSD Lowprofile SoundBase...
Code for a ford 4600 cd radio from a 2001 focus, serial number M191889
yr code is 8917
for free ford radio codes email sywright@yahoo.co.uk
Jan 22, 2011 | Ford Car Audio & Video
No sound from radio in 97 ford explorer already r...
Turn the radi volume up high
Can you hear any hiss or noise?
If Yes..then the problem is your radio or aerial.
If NO , then the problem will usually be the speakers
Check connectors+wiring
May 21, 2010 | 2002 Ford Explorer
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Mar 14, 2008 | Midland 75-822 40-Channels Handheld CB...
Car Audio & Video Logo
415 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
