Question about Acer Aspire 3680 Laptop
My Touch pad does not work, can someone help? the touchpad suddenlly stops working while i was using it
  • HabenAmar Apr 09, 2008
    Acer Aspire 3680 2125
  • Anonymous May 28, 2008
    I have acer aspire 3610 my touchpad suddenly stop working
    Sergeant:
    Champion:
  • 244 Answers
Try to remove battery. Turn on you computer without battery. battery can cause keyboard and mouse not working.
also make sure your touchpad is enable by using fn+F7
if this is still doesn't work, it's mean your touchpad itself is bad.
Posted on Apr 09, 2008
Determine which BIOS version is used on the laptop. After reinstall/downgrade to Win 2K Pro, my keyboard/mousepad would only work without the battery. After flashing the BIOS, things worked out well and all is functioning normally
Posted on Apr 10, 2008
Touchpad buttons stopped working. movement of mouse works fine
Are the drivers installed for the touch pad? Try reinstalling the drivers or go into the setting for your touch pad and see if the buttons are disabled.
Try the link.Possibly it can help you.
What to do when your laptop touchpad stops working
Oct 26, 2015 | Acer Aspire V5-122P-0864 11.6" Touch...
Sony vaio touch pad scroll
need to download the touchpad driver and install in your laptop.
Sep 11, 2013 | Computers & Internet
My mouse touchpad stopped working all of a sudden. I have also enabled the synaptics touch pad in device settings in the control panel. after doing all these also my touch pad is not working.
Check the keyboard it's possible the touchpad has been deactivated. You can toggle fn keys (fn + f2) or any fn key that has touchpad drawn on it. If this doesn't help. Am afraid the touch pad connector has to be checked & replaced in computer repair shop
Jan 27, 2013 | Lenovo Computers & Internet
Touchpad will not work after boiling water underneath it for 12 minutes without fan humidity cause touch pad to stop working , I have a GE mdv 2040 with green display touch pad
you can change the touchpad to help with this but whenever you have a microwave over a range you are going to have issues with this. you have to make sure you use the vent on high whenever broiling anything to prevent the moisture from getting in the touch pad because all your touchpad consists of is two stickers and some flat wire so moisture can easily getting into it cause it to stop working for a period of time. but changing it is the best thing you can do
Jun 02, 2010 | GE JVM1860 Microwave Oven
Emachines e725 Touchpad Not Working
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple.
May 02, 2010 | Acer Aspire 3000 Notebook
No cursor activity
Dear Sir,
Generally for compaq there is lock for touch pad you can see a moving lock below or above the touch pad. If locked the tochpad button,touch pad not sensitive.So open the lock and now you can move pointer using touch pad. see this pic
http://icerazerstudios.com/wp-content/gallery/random%20images/touchpad.jpg
there is black color button lock appear at the upper border of touchpad.
Jul 30, 2009 | Compaq Presario CQ60-204NR Notebook
My touch pad has stopped working
Hi there'
Hold down Fn and hit F7 to see if the touchpad reactivates.
Please post back if you have any more trouble.
Good luck and thanks for using FixYa!!
May 11, 2009 | Acer Aspire 4720 Notebook
My touchpad is not working
install the tachped dirver in laptop and
check it ........and 2nd option is remove the touch pad and install new one more info www.compudesk.in
Mar 28, 2009 | Compaq (153515-001) Touch Pad
Touchpad
When the touch pad stops working it's one of three things. 1- A driver glitch, unistall the touch pad drivers from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers automatically. 2- The touch pad connector has worked loose. Take the palm rest with the touch pad off, disconnect the cable, clean the connectors, and reseat the cable firmly. 3- the touch pad has failed and will need to be replaced. The driver glitch is the most common, I believe that it should take care of the problem. Let me know.
Aug 06, 2008 | Dell Inspiron E1705 Notebook
Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
Jun 27, 2008 | Toshiba Satellite A85-S107 Notebook
Acer Aspire 3680 Laptop Logo
151 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
