Question about HP PSC 1210 All-In-One InkJet Printer
HP1210 error meaasge saying to check cartridges, cartridgeschanged and error message persists Any help??
    Scholar:
  • 53 Answers
Take out the Ink Cartridges and check for expiration date mentioned over it. Make sure that they are not expired, re-filled and re-manufactured.
Try replacing the cartridges.
If issue persists, repair the printer mechanism or go for a new one.
Posted on Jun 02, 2010
Error message says "Remove and check cartridge on right" Its a new cartridge I've been using for a few weeks and it has been working fine. I have removed cartridge several times and even cleaned contacts....
The electronics on the cartridge have gone bad. Sometimes cartridges short. Take the cartridge back to where you bought it (they should give you credit for any remaining ink) and buy a new cartridge.
Aug 10, 2010 | HP Photosmart C4180 All-In-One InkJet...
Message says Remove and check color cartridge. We
The cartridge cavity in the printer may need cleaning.... perhaps a colorful "spit wad" is lodged in the cavity.
If the printer will allow, run a "clean nozzle" utility from the printer or computer.
Hope this helps!
Sep 08, 2009 | HP Officejet 7210 All-In-One InkJet...
Error message says check color cartrigdge even
You did take the protective film off the new cartridge, correct?, could also be the contacts that recognize the cartridge ae dirty, also, try unplugging the power cord on the printer and plug back in to reset
Aug 22, 2009 | Office Equipment & Supplies
Received "Low Toner" message. Replaced toner with new Brother cartridge still have "low Toner" meaasge and [printer will not print.
Please check if you removed the Plastic Tapes which is placed in the side lock of the new Toner Cartridge.
Apr 24, 2009 | Office Equipment & Supplies
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
Memory error
Just do 2 steps:
1. Press Stop.
2. If the display highlight "Resume". Press the OK (Check Button).
The display will tell you that a Non-HP Cartridge is installed and Economode is Disabled.
At least, you can now print. The display will show back again to "Ready".
Jul 23, 2008 | HP LaserJet 2420 Printer
Lexmark x5470
A Right Cartridge Incorrect message generally indicates a communication error between the All-In-One and the cartridge. This can be caused by a faulty cartridge; however, it may be due to a simple interruption in the communication between the cartridge and the All-In-One.
The procedures below will help you to identify the cause of the error and resolve the issue.
Rebricking the All-In-One and Resetting the NVRAM
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action 1 Power off the All-In-One and remove the power brick from the back of the unit. Wait 20 seconds. Then reinsert the brick and power the unit back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Reset the NVRAM of the All-In-One
Yes: Continue to Checking the Cartridges.
Step Action 1 Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3 Reinsert the power supply brick into the back of the All-In-One and power the unit back on.
Does the error message reappear?
Yes: Skip to Contacting Lexmark. There is a hardware issue with your printer and you need to contact our technical support center.
No: Continue to step 4.
4 Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts (click here for instructions). Continue to step 5.
5 Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then back on.
Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Continue to step 6.
6 Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then back on.
Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Try printing a test page. If the test page prints, the error is resolved
Nov 11, 2007 | Lexmark X5470 All-In-One InkJet Printer
NEED HELP WITH MY PRINTER
HP PSC 1210 - The Print Cartridge Detected is the Wrong Type * The following message is displayed on the computer: "The color [or black] print cartridge detected is the wrong type" * The Check Print Cartridge light is blinking, and the Check Paper light is off. This problem usually occurs after replacing a print cartridge. Soloution: http://www.whatmobile.com.pk/hp/hp1210.htm
Aug 05, 2007 | HP PSC 1210v All-In-One InkJet Printer
Error message
disc error msg playback may not be available on this disc.....help
Mar 27, 2007 | Symphonic WF803 DVD Player/VCR
HP PSC 1210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
