1996 Chevrolet Blazer Logo
Posted on Jun 01, 2010
I have a 97 blazer starts fine stalls at 230deg starts when cool
I have a 97 blazer starts fine runs untl hot and thn shuts down//wait 1 hour wl start again untill hot then wl stall agn PLEASE HELP ME// already changed feuk filter and icm
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jun 12, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
5341
Points
40
Check the electronics in the distributor. Chevs are notorious for the electronics going bad inside of the distributor.
I have 84 ramcharger started fine used for about 1/2 hour plowwing driveway shut off would not restart until cooled off 2nd time it has done this?
Sounds as if the ignition control module is getting hot and not allowing it to restart. Had the same issue with a Dodge b-250 van, except for the plowing part. It would run for about an hour and start sputtering and shut off. After it cooled down, van would start and run great for the same length of time and do it again.
Drivability problems after driving 20 - 30 miles
Try changing or switching out the distributor. Most likely getting hot and shuts down. Does it crank but no start whenever it stops? May only start when it cools down again.
I have a 97 expedition and it will start with no problem but when i drive and the suv and it gets to the normal tempeture and i turn the car off it will not start i have to wait for 20 min or more until...
I would say your starter is faulty. Since the vehicle runs fine, and doesn't start up after being shut off until it has cooled down, it sounds more like a starter that loses contact when it is hot. You could check the starter terminals for 12 volts using a multimeter when the key is turned to Start the engine after warming up the engine and shutting it off. If 12 volts are present, replace the starter. If 12 volts are not present, check the Starter relay.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2helpful
2answers
Every now and then it will stall out. just wait about 1/2 hour and it will start up and run good again
Sounds like the "Crank Position Sensor"...especially because it will start fine a few minutes later...tough to confirm by codes on this one...do any of your gauges go beserk when your Buick stalled? This would again point to the same intermittent starting and running problem...part is about $35. May need help to install...:)
My 1988 chevy beretta v6 2.8 liter runs fine starts nice, when it gets running and gets hot sometimes it will stall out not all the time but just sometimes, and when i have been drivin it for a while say...
its common for chevy vehicles-you have a problem with your crank positioning sensor,our 06' colorado does that- sensor maybe $50.00,look into that sensor..
hope that helps you-good luck!
My 97 buick runs cold stalls when hot wont start for 1 hour
Sounds like it is fuel related. Ck fuel pressure to be sure. Also ck the pressure regulator on the fuel rail, It is a small metal cylinder at the end of the fuel rail to ck pull to vacumn line off (hot not running after shutting the engine off). If there is fuel in the vacumn line it is bad. Good luck
1997 chevy blazer trouble starting
97 don't have carb that year its TBI injection . Inspect/fuelpump relay/pressurereg.switch/pump/filter
3answers
I have a 350 chev, motor, put in a new cam and lifters adjusted lifter, set timing .vacume on carb, problem is when i drive the car and turnit off i have to wait till the motor cool down to start .i am...
I have a '81 Firebired that did the same thing with the factory-issued Flintstone-mobile 3.8L V6. Everything but the starter worked correctly: new 185 thermostat, perfect 50-50 coolant misture, no leaks, etc., but still had to wait 1-2 hours for a cool down.
It may be that your original starter is dying. Your starter relay is over-heating and opening the circuit. You can replace the starter and/or buy a pre-made heat shield for the starter or fab one yourself. Regardless, just remember that the goal is to keep the starter as cool as possible.
To prove this is in fact the problem get the engine hotter than usual in your driveway then shut it off. If it won't start cool it down with a bag of ice (don't burn yourself). Should take less than 5 minutes to cool it to start.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
