Question about Kenmore 24032\24036 Top Load Washer
Cold water not running
Cold water just trickles yet hot water works fine, wondering if there is a clog in the line somewhere
    President:
  • 1,218 Answers
Good day,
Could be one of the screens is clogged up, and that would mean removing the hose, checking it, then checking the inlet screen on the valve itself.
However, it's usually the valve diaphram swelling, requiring installing a new valve.
Here's a tutorial. It's not for replacing the valve which is a nuts and bolts job, but gets you to the area to access the valve. Kenmore's are made by Whirlpool.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Posted on Jun 01, 2010
    President:
  • 1,430 Answers
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/topwaterinletvideo.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Lg intellowasher wf-t1081tp hot water intake slow.
wich is connecting with inlet hose & inlet valve,,back of the machine,,thre is one filter in side the valve, remove &clean it,,pls
Apr 12, 2014 | LG Washing Machines
Water is just trickling into the machine and both water lines were checked to see if they were clogged
there are 2 solinoied valves connected at back of machine there should b when u remove the hoses small filters in them if they are blocked wash out and try again but the most probable cause is the valves need 2 replace the faulty one hot or cold valve if u have only cold fill like new ones then just that 1 hope this helps
Oct 02, 2012 | Siemens WFXD5200UC Front Load Washer
I have a single control, new glacier bay bathtub faucet control. i don't have the hot water heater hooked up. i'm only getting a slight trickle out of my faucet whenb i turn the knob to cold. is it...
it is likely required. many new faucets have what's called a pressure balance valve that helps prevent scalding by lowering the pressure of hot when the cold pressure drops (due to a toilet flush or other water being run). Because you have pressure to only one side, that can cause the valve not to provide the necessary volume.
Dec 12, 2010 | Plumbing
Hot water trickles in swhower--works fine on other faucets--cold h2o flow fine
Clogged galvanized pipes. Replace with Pex or Copper lines. Or bad Moen cartridge- see department store for replacement or call Moen direct. You can get the # from gethuman.com
Nov 11, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Apr 18, 2009 | Kenmore 23822 Top Load Washer
Hot and cold water trickles from faucet--seems nearly clogged.
The debre from turning off the valves comes through the lines and clogs up,usually the aireator,the screen at the end of the faucet. Take aireator off ,,colena and reassemble. If that does not work,disconnect the  lines at the shurtoff agaoun and look for hte obstructions for the aireator back to the shurtoffs.
Apr 06, 2009 | Whitehaus Kitchen Single Handle Faucet...
The cold water does not run it trickles, hot water runs very fast
If both solenoid coils check the same, you probably have a clogged supply hose. Check that the filter screens inside the hose (if present) and the fill valve inlet are clear of mineral buildup. Try switching the hot and cold supply lines to see if the trouble moves from cold to hot. If the cold still only trickles in, replace the fill valve.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
GE Washing machine cold water barely dribbles in
Yes remove the hose from where it connects to washer look inside water valve and remove plastic screen with needle nose pliers Without damaging it. Also make sure that it gets back in proper as the valve will be damaged without it.
Jan 19, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
80 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
