Question about Empire RH35 Mid-Size Heater
No problem lighting the problem lite and it stays
No problem lighting the pilot lite and it stays on. However, when the thermostsat is turned on,the main burner comes on, however after a minute or two the unit shuts down and the pilot lite goes off.
4 Suggested Answers
  • 67 Answers
SOURCE: Empire BF-30-1 Main Burner problem
flame sensor,just take some fine sand and lightly sand,it will be where the flame hits one of the burners,should look like a probe,if this helps please give me a fix ya
Posted on Jul 15, 2008
  • 18 Answers
SOURCE: my dv35 wall furnace pilot light on main burner will not light
lightly tap on the area where the wires are connected. the valve will stick at times. try that.
Posted on Nov 08, 2011
  • 18 Answers
SOURCE: pilot lights but no main burner
Is there a way to check for gas pressure even if just a slight loosened connection to hear it then quickly re-tightened. Otherwise the main valve is not working as it should and will need to be serviced or replaced. Thats all i got.
Posted on Dec 07, 2011
My jotul 200 direct vent gas stove pilot light won't stay lit. The pilot lights normally, and fires when the thermostat calls for heat. But when it turns off the pilot goes out as well. We cleaned ou
There's a little screw that adjusts the pilot light. It is usually on the block with all the other valves. Follow the pilot lite supply line to where the screw probably is located.
Nov 22, 2013 | Stoves Heating & Cooling
My pilot light won't stay lite,replace thermopile and still doesn't stay lite.
Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
Apr 18, 2013 | Cecilware FMP40 Deep Fryer
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I lost my manual and dont know how to light my R15 gas wall heater.
if its a stnding pilot turn the gas control nobe to pilot hold down light pilot when lite hold down for 30 saconds,then relese and it should stay lite.
Jan 20, 2011 | Heating & Cooling
Can't get pilot light to stay lite in oven
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Apr 04, 2010 | Stoves Premier 600GRa Gas Single Oven
It wont lite, how do you lite the pilot, where is it located, do you have a manual i have a coleman presidental 3 furnace
There is a window directly above the gas control valve. Either a spring held latch or a screw off cover need to be removed to access the pilot. To light the pilot, turn the knob to pilot and hold down while lighting pilot. The pilot in straight back inside the hole about 10 inches. Use a long fireplace match or rig a wire to hold the match. Once the pilot lights, hold the control knob down for about 30 secs., if it stays lit after release, turn to "On" and operate normally.
Dec 13, 2009 | Tools & Hardware - Others
Can't get the pilot to stay lite after I turn the knob to the "on
sounds like a thermocouple its a metal proble looking thing nex to the pilot light with a small copper tube attached to it that goes back to the burner control.
Aug 04, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Gas firelog pilot light will not stay lite
try to replace the thermo couple
Nov 25, 2008 | Heating & Cooling
Empire RH35 Mid-Size Heater Logo
57 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
