Question about Electrolux EWDW6505 Builtin Dishwasher
Display panel won't light. Can't turn on the
Display panel won't light. Can't turn on the dishwasher.
Checked and reset circuit breaker
  • 1314 Answers
SOURCE: Maytag dishwasher MDB5601AWS won't turn on
ok under the bottom kick-plate you will find a tech sheet first id start with where my power comes in under the kick plate second remove the front panel and check the door switches third check the control for a fuse or burned wires resistors etc refer to the tech sheet but it sounds to me like a power problem
Posted on Jan 25, 2008
SOURCE: GE Max dishwasher no lights on panel
I reset the breaker and still doesn't work. Any suggestions?
Posted on Jun 22, 2008
muttandjeff
  • 359 Answers
SOURCE: Nearly new Electrolux dishwasher - DEAD
2 THINGS COME TO MINE EASY CHECKS , MAKE SURE THE DOOR IS CLOSING PROPERLY AND THE DOOR SWITCH IS MAKING UP WELL AND CHECK TO MAKE SURE THAT YOU HAVE 110VOLTS LEAVING THE BREAKER AND @ THE DISHWASHER CONNECTION IF IT HAS A RECEPTACLE ON THE DISHWASHER END TRY TO PLUG IN ANOTHER DEVICE SUCH AS A DRILL OR SAW OR OTHER APP, TO SEE IF IT WILL RUN THIS IS A BETTER CK THAN A METER BECAUSE IT PROVES IT IS PASSING CURRENT AS WELL AS VOLTAGE , METERS ARE NONE LOAD DEVICES AND CAN FOOL YOU
Posted on Jan 10, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Dishwasher will not run. I have checked the
Hello there:
My dishwasher will not work at all. Investigate these four areas if your dishwasher is not working at all:
Power Supply
Your dishwasher may not be receiving any power. It is somewhat difficult to check for power at the plug outlet because the plug for a dishwasher is usually behind the unit. You should make sure all the circuit breakers of your circuit breaker panel are in the correct positions, or check to make sure no fuses of your house fuse panel are blown.
Door Switch
A properly functioning door switch will shut your dishwasher off when the door is opened. A defective door switch may not allow your dishwasher to operate at all. Examine the door switch and test it. If it is inoperable, it will have to be replaced.
Cycle Selector Switch
It isn't very common, but it is still possible that your dishwasher's cycle selector switch has become defective. Test the switch to determine if it is the cause of your problem. Replace it with a new one if it is.
Timer Motor
Your dishwasher timer will not function if its motor is defective. And if your timer is not functioning properly, then the dishwasher itself will not function properly. Test your dishwasher's timer motor, and if it is broken, you can replace either the entire timer assembly or just the timer motor.
Posted on Dec 26, 2009
SOURCE: MDBH945AWW maytag dishwasher panel lights will not
These control boards do not have fuses on them. I opened mine up when the front panel touch pad stopped working and the LED indicators were anemic. This is a sign of the ribbon cable connections have oxidized. The ribbon cable connects the touch pad to the control board.
Others have written up nice solutions on similar Maytag diswashers with the touch pad.
http://www.fixya.com/support/t387192-maytag_quiet_series_300_no_power_touch
The previous expert shows that you can diagnose this by using a 10k resistor and connecting pin 6 and 10 on the ribbon cable connector and it will start the dishwasher (you have to trip the door handle and carefully do this with the power on). This proves that the control board is fine and ribbon cable connections are the problem. Don't forget to quickly trip the door latch once the dishwasher starts.
My solution was to purchase a contact cleaner called Deoxit. You can order from RadioShack.com or get at Frys. Spray Deoxit on both the ribbon cable end (removed) and into the connector on the control board. Deoxit removed the oxide on the connectors. The twin pack Deoxit spray comes with a solution that helps prevent corrosion. I am 1 day into the successful repair of this model Maytag dishwasher.
Previous people have suggested heat and steam get into the control board and oxidize this connector. I notice on the top right where the control board sits, there is a gap to allow steam to get into the door/control board area. I used bathroom caulk to seal both sides of the door to hopefully prevent further corrosion.
Posted on Apr 11, 2010
Elctrolux dishwasher won't start, display won't light. Any suggestions?
Good Morning Friend,
I understand your Electrolux dishwasher, model# EWDW6505GS, seems like it is not receiving power to the control panel. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. If you are still not receiving any lights, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing your control panel to not have power.. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Electrolux EWDW6505GS Fully Integrated...
Blinking light on Kenmore Pro 13873K dishwasher: won't run
May be the drain pump is jammed. Try to clean the area and after that try to reset the panel. Download the user manual and there must be the reset sequence.
Nov 18, 2017 | Kenmore 13873 Stainless Steel Built-in...
My Paloma tankless water heater stopped working after we had a block out, all the lights are working and doubled checked the electrical connector.... it just won't turn on as it should when I run the...
Try reseting it by unplugging it. Also is there any display lights on (troubles). If that dont work it might have fried the circuit board in the black out.
May 09, 2011 | Heating & Cooling
My dishwasher was in the middle of a cycle and it just quit. The buttons dont light up. It doesn't turn on at all. What could be wrong with it?
Sonya, have you checked the circuit breaker in your home's circuit breaker panel to see it has been tripped? Also, is the dishwasher door tightly shut? If the breaker is tripped, reset it to see if the dishwasher trips it again. If it does, either breaker is faulty or the dishwasher has a short circuit in the electrical circuitry. You'll need an authorized service person for that.
Mar 21, 2011 | Heating & Cooling
Had a power failure from bad weather now the dishwasher is dead? checked the fuse box the breaker is fine, there are no lights on the display panel. what is the reset procedure for this dishwasher?
Try turning the breaker for the dishwasher off for 30 seconds and turn it back on. This should reset the dishwasher control board. If it still doesn't work then most likely the power failure burned up the main control board. The control boards in the newer dishwashers are sensitive to any type of power surges or failures.
Hope this gets it running for ya.
Dec 15, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
No power or lights in the front panel
Check the fuse / circuit breaker inside washing machine. There may be a extra control circuit fuse normally on the control PCB.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher does not turn on. it is plugged in but
These are just some possible solutions that are worded for general assistance, I'm sure you have checked many of these things but others may not have;
The circuit breaker in the electrical panel may need to be reset. Hopefully it is labeled and will be easy to find without cycling power to everything else in the house.
The dishwasher may be on a GFI (ground fault interruption) circuit. The outlet may have a reset button on it that needs to be pushed or the circuit breaker in the electrical panel may have a built in GFI that needs to be reset.
Many dishwashers are installed with a light switch in the vicinity of the unit that is used as a disconnect. The light switch will cut power to the dishwasher if turner off. The switch is sometimes above the counter and sometimes below the sink.
There is also the possibility of a faulty On/Off button or dishwasher circuit board.
Dec 19, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Electrolux EWDW6505 Builtin Dishwasher Logo
46 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
