Question about Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher
Maytag MDB8600AWB dishwasher, has power to front panel,all buttons lite up except normal wash cycle lamp will not lite up. When any load button is pushed the main window displayes the flashing time then after about 40 secounds it stops , thats all it does. Will not start, circuit breaker has been reset. drain hose has been checked, water supply has been checked, can't run diag codes
Why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Nov 17, 2011 | Maytag Dishwashers
I have a Maytag Quiet Series 400 and I can't get it to run on Normal,lite or other. I get a code 82 that appears. What does this mean?
My Maytag quiet 400 series is doing the same thing-buttons aren't responding or working. And now a second problem...it has become very loud and sounds like it is chewing up all the dishes.
PattyQ
Jan 10, 2010 | Maytag Dishwashers
Frigidaire pld4375rfc2 dishwasher
don't buy this manufactors products the are not weel made!
Aug 26, 2009 | Frigidaire PLD4375RFC Dishwasher
Control panel lights but won't start
the front control panel fries out.. We had to have ours replaced after 7 months ... after that was replaced it only lasted 2 months... WE ARE VERY disappointed and will be calling once again tomorrow. The dishwasher is not even a year old yet!
Aug 16, 2009 | Maytag MDC4650AW Built-in Dishwasher
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front load washer maytag stopped working during wash
the start button is part of the board their.if you hear frying noise their when pushing it there ,you may have a failling board.god bless your way.Tom
Dec 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
My new Epic Z is only one month old
sounds to me like there is a short in the wiring or control board i would call the warranty company to come fix it
Dec 30, 2008 | Maytag EPIC MFW9700S Front Load Washer
Intermittent problem, unable to select normal wash cycle/start
restart curcuit board sequence
push start hold down air dry and start until lights blink and machine starts then it should work normal
most dishwashers have an instruction booklet behind the botton panel that is nearest the floor you wll have to remove the panel it has a couple of screws. the booklet should be there unless installer took it.
If you omly replaced the front panel board then you may have to replace the circuit board inside the door. It works like a mother board in a computer. Good luck
Nov 17, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Washer will not restart.
unplug it wait a few mins---- that should solve it sometimes these machines go in to a a "soft lock" condition
Sep 30, 2007 | Whirlpool GHW9100L Front Load Washer
Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher Logo
128 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
